Removing Stuck Wheel
Southern
Post by Southern »
Any tricks for removing my stuck rear wheels? The lug nuts come off easily but my aluminum wheels are stuck. I had this happen last time I went to rotate my tires. The tire guy couldn't get them off, he beat on it with a big hammer. When I got it home I was able to get them off by kicking the tire from the back side. This time I tried kicking from the back side but no luck after soaking with penetrating oil.
I've read that putting on the lug nuts finger tight and drive the van back and forth several times will break them loose, anyone try this?
BTW, my Astro recently turned 200k miles, I still have the original fuel pump, engine and trans.
92 Astro Conversion Van 2WD
Vin Z Engine
Eaton Posi
Overnite
Re: Removing Stuck Wheel
Post by Overnite »
When I worked at a tire shop most of the time we could kick them off from behind but when we couldn't we took a short piece of 2x4 and put the end of it on the bead of the rim in the rear and whacked it with a big hammer. This should work if you hit it in one place and turn the rim a little and keep working your way around it. If you get them off, put some anti sieze around the center of the brake drum where the hole in your rim contacts it. I hope this helps you.
6spd_monte
Post by 6spd_monte »
You can use a long prybar or piece of wood as a lever. Stick it between the edge of the drum and the wheel on the inside and lever away. If it doesn't come lose, rotate the wheel 90 degrees and repeat until it comes off.
Alternatively, you can loosen the lug nuts and just drive around the block until you start hearing clunking noises on corners.
:muhaha:
-James
1987 LT
249,000 miles
Southern
Post by Southern »
Thanks for the suggestions.
Since I don't have a lift it would be difficult for me to swing a big hammer on the inside of the tire. I will try loosing the lug nuts and drive around the block.
The last time I had the wheels off (1 year ago) I put anti-seize on the hub of the wheel. This works well if you remove the wheels at least every 6 months but over a years time it doesn't. I'm wondering if a thin coating of synthetic grease would work better.
Vin Z Engine
Eaton Posi
Kidhauler
Post by Kidhauler »
The other idea I have heard is to use a bee's wax toilet seal. Heat the rim and brake up a little and melt the wax around the centre and it should help lube the tire and break free.
1999 Safari Touring edition.
teal green
300 000 kms
ihatemybike
Post by ihatemybike »
Some may not like this idea, but it does work. Loosen the lugs, snug them back up, then loosen them a quarter turn, now drive the van a little. Slowly around the block is usually enough for me to break them loose.
Use extreme caution when trying this method. The safety of others is more important than breaking your wheels loose.
6spd_monte
If the wheels are stuck we can speculate that the drums may also be stuck. I bet that the wax idea would help free them up too.
-James
1987 LT
249,000 miles
