Hard Lesson to learn...double check lug nuts.:-(
Logan
Post by Logan »
Went rough trucking on Wednesday night. While towing, my exhaust usually rattles on my hitch...I heard a lot of noise but nothing out of the ordinary until BOOM!!!!! I'm pretty sure I didn't retighten my lug nuts after swapping my rearends. Although the passenger side was still tight..... And there were no issues towing to the fairgrounds.... oh well, hard lesson to learn......
1988 Astro Shorty full cargo - 350 TBI - 5 speed
1993 Passenger 4X4 Astro 305 TBI V8 -2 speed transfer case 5" custom lift - Built by Lockdoc
2015 Ram Promaster City - work car
2004 AWD Express 5.3
2005 Express 15 passenger 6.0
1984 Beauville Full Size Sport Van- built TBI 355-electric fans- 4L60e 95,000 original miles
2001 International School Bus
Rileysowner
Re: Hard Lesson to learn...double check lug nuts.:-(
Post by Rileysowner »
Ouch. That is lots of damages. Thanks for the reminder.
Cobra
Post by Cobra »
oh that sucks i got pretty close to losing my wheel on my way to NECO last year. I'm always going to re-torque my lugs after a shop works on it from now on
Post by mdmead »
Ouch!
I can relate though. I had a rear wheel come off my old Ramcharger and not only crunched the rear panel but also had one of my snowmobiles come off the trailer I was towing and land upside down in the middle of the road. ](*,) ](*,) ](*,) ](*,)
astroturf
Post by astroturf »
First and foremost, you are O.K.
Secondly how much brake/rear end damage?
Rebel
Post by Rebel »
:poke: not good,,just glad you weren't running 70 down the highway.
Happened to my wife with her Grand Cheorkee. Went in for new tires,,,came out and half way home the back left mag rolled off and actually was ahead of her. Didn't hurt anyone but did do a little damage. DA had put the wheel back on and no lug nuts. :-k
VIDEO
lockdoc
Post by lockdoc »
Oh man, that sucks! I feel for ya bud. Your luck is about as good as mine. Almost happened to my blue van on the way to Canada once. Caugt it before it went flying though.
Current:
01 AWD - Stock
98 AWD - Stock
Past:
94 RWD - 350 V8 - sons van
92 RWD - stock - sons van
93 RWD Shorty - project
89 RWD Shorty - parts van
Moreforles
Post by Moreforles »
almost happened to my wife's grand caravan on trip to VA. had a hot spot on rotor, so shook a little on hard braking..... seem to be getting alot worse around parkersburg WV. pulled over on the side of the road.... had broke three studs off, only had two lugs holding the wheel on, barely, a couple more minutes on the road and I'm sure they would have come off as well....tightened down last two and inched it into town, it was after 10 pm, both the parts stores were closed, so we stayed overnight at a motel, I change 3 studs and replace lugs while my wife and kids ate breakfast.... then we continued on the trip.... now I give them a tighten before any long road trips or when anyone else has had them off..... The Tireman, over tightens them to the point where I can't get them off without a three foot cheat bar on fourway...
Logan
Post by Logan »
astroturf wrote:First and foremost, you are O.K.
Everyone was okay, it was just my Wife and I wearing our seatbelts. I think the trailer actually slowed us down a bit. That or the backing plate digging into the pavement. lol
I had to purchase a new drum, hardware, wheel cylinder and 5 studs. Cost me about $100 to get it drivable again. I had the spare wheels and tires from one of my other vans I junked.
I took it to a local body shop for an estimate on Saturday. We carry full coverage on it cause of the tool and parts. Going to cost about $2300 to fix. Not sure whether we're going to screw with the insurance or just leave it be. I have no desire to argue about a 16 year old astro with 330,000 miles and a V8.
astronut74
Post by astronut74 »
I forgot to do that once. I got lucky though, I was driving down the road at night and I actually heard the first lugnut and stud hit the road when it broke off. I wasn't sure at the time what it was, but it was enough for me to pull over and check things out.. I noticed one of the studs had broken off, and I quickly got the rest of them tightened..
Now when I change my tires, I leave the wheel chocks under the tires until I double checked the lugnuts.
Steve O
94 2WD Astro EXT
179,000 miles and counting
Going from an 8 seater to a 4 seater
phr1$k37
Post by phr1$k37 »
Sorry to see / hear the drop. Glad you are alright.
So just curious ... how many of you torque to spec? :D
At the shop I just use the air-gun. If at home I re-check after driving for just 10kms.
astroturf
Post by astroturf »
I Torque. Cause it says torque. Jim
I ALWAYS torque them for a couple reasons. 1. keeps the rotors and drums from warping and 2. makes absolutely sure the wheel is tight. Steel wheels I generally don't recheck but aluminum wheels get a re-check after a short trip of 20 - 50 miles.
phr1$k37
Post by phr1$k37 »
Blah ... Dean is always right ... looks like I am going to have to by my replacement torque wrench for the tires ... I dont need to mess up my rotors.
Kidhauler
Post by Kidhauler »
When ever I go to a shop that has had the tires off. I always loosen all the lug nuts and then re tighten them with the wrench from the car. That way I know if I put them on with that wrench I can get them off with it in the event of a flat tire. I nearly lost a tire in High school because I let a friend put the tire on and didn't check his work. If we go on a road trip I check all the lugs before we leave and then usually once on the way. Normaly when we stop for the night or on the second fill up of the day while everyone is running for the washroom at the gas station.
1999 Safari Touring edition.
teal green
300 000 kms
