Changing rear shocks 2004 astro w/rear air conditioning
STEPHAN
Post by STEPHAN »
New to the site great information here, I went to remove the rear shocks and noticed that the top rear shock bolt on the drivers side won't come out unless I move the rear ac line has anyone ran into this, the bolt has to be pushed out and the ac line is in the way, theirs clips that hold the line against the frame if I take the clips off will I be able to move the line enough to get the bolt out
2004 2WD Astro 192,000 miles
Stroverlander
Re: Changing rear shocks 2004 astro w/rear air conditioning
Post by Stroverlander »
You don't need to remove the upper bolt. Loosen and remove lower shock nut/bolt and slide out of mount then loosen and remove upper nut and slide shock off of bolt. If the spare is in the way, lower slightly so you can remove.
Post by doyoulikeithere »
X 2
STEPHAN
Post by STEPHAN »
Thanks a million piece a cake changed both shocks in under two hours now for the fronts that's another story
Wanna Know the trick for removing the fronts, easily?
or are ya gonna just go for it?
STEPHAN
Post by STEPHAN »
Need all the help I can get, read somewhere on here about snapping the top nut
Vanjoe
Post by Vanjoe »
I DO !!!
1998 Astro. Sterling Hi-top Conversion. 1st Second gen owned.
Former ....
90 Astro shorty conversion,$500 short term driver
91 ext Astro bad body,bad motor $325, became a 350/4bl cruiser with all under hood acces working.TOTALED..my fault
88 Astro shorty conversion 177k-270k,threw rod. $2500
85 Astro mint body ...totaled 9 days later...not my fault. Paid $1k, insurance gave me $2k
86 Astro shorty 147k-242k, $2500. sold running!
STEPHAN
Post by STEPHAN »
can't get the front ones off can't get a wrench in there only a socket and that leaves me no way to keep the rod from turning can't put nothing on the top to hold it, if I break it , when I put the new one in how do I tighten top nut down if I can't stop it from turning
STEPHAN wrote:read somewhere on here about snapping the top nut
You got it ! :supz:
(2wd only) Put a deepish socket over it and just bend it over till it snaps.
Then it can drop out the bottom
Dont worry bout tightning the new one, it wont be an issue.
