It is currently Sun Aug 20, 2017 1:38 pm
Post new topic Reply to topic  [ 1 post ]
 Post subject: Bal joint/control arm install 99 AWD
PostPosted: Fri Aug 11, 2017 2:39 am
I am replacing my upper control arms complete with bushings and ball joints. When reattaching the ball joint to the steering knuckle (spindle?) how do I know when the ball joint bolt is all the way in? I've threaded on the castle nut a bit and I can access the cotter pin hole but it seems like I could continue jacking up the lower control arm /knuckle into the ball joint. Also, on an AWD how on Earth do you torque that nut? The drive axle (CV joint?) is right there.
As an aside, how do you torque the front upper control arm nut (driver side)? Only access is with box wrench. Should I lower the van down first?
Thank you!
99 Safari AWD -> 4WD slowly Update: Auto 4wd, 2Hi, 4Hi work, no luck with shifting to 4lo
Users browsing this forum: No registered users and 6 guests
