replacing a steering column...HELP!!!
Astroken
Post by Astroken »
i need to replace my steering column in my 90 astro, with a 4.3,2-wheel drive, tilt, any help would be appreciated! thank you
Re: replacing a steering column...HELP!!!
Post by doyoulikeithere »
Astroken wrote:i need to replace my steering column in my 90 astro, with a 4.3,2-wheel drive, tilt, any help would be appreciated! thank you
Its just So Easy!
1 bolt under the hood separates the column from the shaft.
4 (or so) small screws hold the plate against the floor.
2 bolts hold the column up under the dash by your knees, let it drop.
Unplug the wire plugs on the column.
Pull.....
If the new column has more options than the original, no biggie, they just probably wont work if you didnt have already.
Eg: If New column has cruise control but your van never did, it isnt going to magically Start to work, but it wont hurt anything.
However, you want to be sure your new column has the options your van did, or the CC you used to have wont work with a column that has no CC controls on the turn signal stick. I guess you could swap the turn signal stick too though.
Tilt or no tilt, either can replace the other.
Post by 1Gary »
Astroken
Post by Astroken »
Thank you very much for all the help and info. My son and I can't wait to get started!
Logan
Post by Logan »
1988 Astro Shorty full cargo - 350 TBI - 5 speed
1993 Passenger 4X4 Astro 305 TBI V8 -2 speed transfer case 5" custom lift - Built by Lockdoc
2015 Ram Promaster City - work car
2004 AWD Express 5.3
2005 Express 15 passenger 6.0
1984 Beauville Full Size Sport Van- built TBI 355-electric fans- 4L60e 95,000 original miles
2001 International School Bus
Astroken
Post by Astroken »
Just wanted to say thank you for all the help. got the column changed out, and it's running great!
took about 1 1/2 hrs. not bad. you guys rock!!! :supz:
THANKS again. pic coming soon
I-Drive
Post by I-Drive »
Hey all!
I know its an old thread but I was wondering if the 96 column was the same as the column change in this thread.
I have to go pull one today and want to be sure of what I am after.
Is my 96 a mechanical linkage or a cable?
Found it.
