Loose Steering
Jennifer
Loose Steering
Post by Jennifer »
Hey guys,
My steering has been kind of loose... you know, the wheel turns about a quarter turn before the car will actually turn. It's really no big deal, but I was wondering of there was a way to make it a little tighter. I replaced the idler arm and lower ball joints (they all had to be done anyway) and hoped that would help, and it did a little. I know it's a pitman arm and not rack and pinion so I'm not sure how to approach it. Any tips would be appreciated! Thanks!
1995 GMC Safari AWD
Re: Loose Steering
Look for the "Steering Box Adjustment" thread stickied in this section. :yawinkle:
Oh, and there are 2 idler arms. If one was bad the other is too...most likely.
Re: Loose Steering
Post by 1Gary »
Hey Jen.Kind of a FYI suggestion after the replaced parts.It is a recommended to use only Moog brand name idler arms,steering parts,etc,because they last the longest and are the most durable.
Jennifer
Re: Loose Steering
Post by Jennifer »
I did use moog, but I was told by the parts store, both the physical one and the online one that there was only one on the AWD....
1995 GMC Safari AWD
Cobra
Re: Loose Steering
Post by Cobra »
only one part number yes but two required
Re: Loose Steering
Post by 1Gary »
You just might to be careful with on line purchases.Some have been found to be counterfeits.
Jennifer
Re: Loose Steering
Post by Jennifer »
I purchased the moog in store and was told I only needed one... I guess I'm going back for the second. :(
1995 GMC Safari AWD
