If I where you,I would go into your local parts store and have them pull the pads for both.(non-Astro 2500 series truck and Astro stock pads.)Clearly you will see if the truck pads are bigger.From what I am getting here is the AWD ones are the same size and the RWD ones are bigger. The ones for my 1994 LT are smaller and the truck pads are bigger,but I honestly don't know about you yr van.LaGrasta wrote:Do I understand this correctly, AWD has larger pads than non-AWDs? So for my '99 non-AWD, this would be a noticable upgrade, correct?
The Lt's front brake conversion
Re: The Lt's front brake conversion
i am AWD and my stock pads were a Eurorotor F1D369 they don't seem smaller then the 3500 series i used but on side by side comparison the pad surface area is larger the pad i have on now are a F1D845. i just went and compared the wagner MX369 and MX845 the look almost the same but again the actually pad material has a larger surface area. like other AWD people have said in this thread when you first put them on you'll have a huge smile on your face but you get used to them and they wear down i feel they are an improvement but not a huge one. that's my 2 cents at least
- Retired
I am 2wd, and my brake pad upgrade was from stock size Astro (riveted pads) to the 3/4 ton pick-up pads (non-riveted pads) you can certainly see the 20% size increase. Never use these CHEAP riveted pads on your van, because when they get low the lining brakes off in chunks between the rivets, and they will go metal to metal real quick. I also Highly recommend not to use the Advance Auto Duralast Gold pads, as they squeak and fade.
At the same time I also swapped over to hydro-boost, and used everything from a `94 (last of the old-style) onto my `86, plus an 11inch rear brake set-up (`92 Caprice cop-car), and my 300hp Astro stops on a dime even when towing 1500lbs on an un-braked trailer (sandrail + gas and camping equipment).
Maybe in the future I may fit the larger calipers.
Nice Post!!!SoCalli V8 wrote:I am 2wd, and my brake pad upgrade was from stock size Astro (riveted pads) to the 3/4 ton pick-up pads (non-riveted pads) you can certainly see the 20% size increase. Never use these CHEAP riveted pads on your van, because when they get low the lining brakes off in chunks between the rivets, and they will go metal to metal real quick. I also Highly recommend not to use the Advance Auto Duralast Gold pads, as they squeak and fade.
Well I called the local Chevy dealer assuming the rotted off dust shields for my 1994 LT RWD van that bolt to the spindles was going to be kind of cheap to buy.NOT!!!!.$56.00 bucks a piece!!! and would have to be ordered of course.So off to the pick and pull to see if I can find some usable ones that I can clean up.Got a price from one of the p/p for 10 bucks each,but of course they can't tell me if they have any and I have to jack the vans up myself to get them off.
Question is anyone know what yr vans I should look at to get the part??.I don't have the old dust shields off and won't when I go to the junk yard tomorrow.
Second question is what tools (sizes of sockets) that I should take with me to get them off??.I assume already that I need the torx for the calipers,crescent wrench for the spindle nuts and dikes for the cotter pins,lug wrench and scissor jack.Not sure what the size is for the bolts that hold on the dust shield.Any thing I am forgetting here??.
I wouldn't bother with them. The ones on my truck were destroyed when the front end was rebuilt and I now have none. The brakes work the same either way.
I took the ones off of my Crown Vic on all 4 wheels when they got rusty. No problems.LiftedAWDAstro wrote:I wouldn't bother with them. The ones on my truck were destroyed when the front end was rebuilt and I now have none. The brakes work the same either way.
Do the ABS sensors mount on the spindle or on the shield? I can't remember, that would be my only concern.
I wish you were closer, Gary. Seems I always have what you need: wheels, no window doors, brake shields. lol.
You still have my 4.3 4bbl intake and carb, so I guess were even.
rlsllc wrote:I took the ones off of my Crown Vic on all 4 wheels when they got rusty. No problems.LiftedAWDAstro wrote:I wouldn't bother with them. The ones on my truck were destroyed when the front end was rebuilt and I now have none. The brakes work the same either way.
I have been in your neighborhood twice before.Once to tow home Ole Yellar and to Blaser's to get the donor.I have also sent parts to SafriRob.If you send those dust shields to me(I pay for the parts and shipping) two things happen.First it get me tons closer to taking the Ole Yellar off the road and to taking the Carb'ed 4.3 out of it.Now about those rear no window doors,please send some pic's.What condition are they in??.Maybe we could work something out for the whole Ole Yellar engine. What big city are you near in Ohio??.
BTW-the run to the junk yard was for nothing.I called them and they told me what time they where closing and when I got there they where closed early for good Friday.Grrrrrrrr
I'll have to see if I can get to them this weekend, I'm working (if you can call it that, lol) today.
The rear doors are solid, in OK shape, I'll see if I can snap some pics. The slider has some damage (a crease in the lower rear), but was solid last time I checked.
They are on a 1994 no window shorty that has a bad trans. Ran good when parked a year ago, haven't stared it since. I'd take $500 for the whole van, or we could work out some kind of trade. I'll even put a set of those dreaded LT alloys on it, lol.
That 4bbl 4.3 would be perfect for my 1981 Monte. It has a DOG 3.8 in it.
I'm not really near a big city, google 43005 or Bladensburg, Ohio. to see where I am.
I do kind of remember a exit for your town when I went to Marty's place.I have a no window slider I got from Dean.If I was interested in yours,it would be solely for the purpose of having a sample to hook up the rods inside of the one I have.I am not interested in having another van here for sure.The rear no window doors,and considering posts of not replacing the dust shields,maybe those dust shields would be the only interest I might have.Honestly,I had hopes of offing the sub frame and engine once I removed the one from Ole Yellar keeping the tranny from it.It is because of storage space or lack of it,is the reason why I would want to make that move soon after I take the sub/engine out.Ole Yellar has been a good starter with one press to the gas peddle even threw the cold weather.It does start slow sometimes if warm,but it it starts.My point here is the carb was rebuilt just before I bought the van and the choke was set right for sure.It has had from day one a leaky rear main seal and I have just been adding oil as needed.I think the Alt needs to be replaced even through it seems to keep the battery charged.Given the swap, I didn't want to spend money on this 4.3 engine,etc.
All this aside,please do post pic's of the rear doors.I have had a line on a J/Y for no window doors(no rust) which was going to be my game plan once I was ready to buy them.But maybe some sort of trade could make a trip to you worth it.
Of course to meet you would be pretty cool too.
Gar
I did look up your location on Yahoo and it would be a 7 hour'er one way.But as everyone knows,I have done worse before.
Gar
Today I got the rotors,grease seals,hoses,and went to the j/y to get dust shields.So I have now all the parts and the brake job will be coming up next.
You'll eat your words on that one, LOL. Other than Mic, who I bought 2 vans from and lives 500 miles form me in St Louis, I don't think I've met anyone from the board. My wife met Logan and said he was cool. No pics yet I've had a lot of problems lately I'll be posting something about it all later.1Gary wrote:
All kidding aside, I'd like to meet you too. You seem like an older version of myself. Bull headed, stubborn, full of wild ideas, etc. All good traits.
rlsllc wrote:You'll eat your words on that one, LOL. Other than Mic, who I bought 2 vans from and lives 500 miles form me in St Louis, I don't think I've met anyone from the board. My wife met Logan and said he was cool. No pics yet I've had a lot of problems lately I'll be posting something about it all later.1Gary wrote:
I think you met Blazer too when he went to Chops for the van.
Here is a update just short of a yr later.First I want to be very clear that I do think this conversion improves braking and that I do not beat on my vehicles.The trade off it seems the larger pad does wear a stock rotor faster.I recently had the driver's side wheel off to put in spark plugs and it seems I could either turn the rotor or replace it.I don't turn rotors or brake drums,so I will be replacing it with new pads to match.I'll grab some pictures when I do this job.But it is fairly wore out.And before you say it,yes the caliper wasn't hung or stuck on the pins.
