It is currently Mon Nov 20, 2017 3:39 am
Post new topic Reply to topic  [ 8 posts ]
 Post subject: security system
PostPosted: Thu Jun 17, 2010 6:50 am
apparently my 2000 has some sort of security system from the factory, and won't start, light on dash below the check eng light, motor just cranks, but wont turn over. So thinking it is some sort of kill switch.... any suggestions on how to disable it... I replaced the battery in the key fob... power lock remote control is working fine, but van still wont start. #-o
I can't wait to get the van back on the road, I'm tired of using my portable carpet cleaner.... and want to use my 16hp truck mount, the portable does an ok job, but makes me work to hard and takes longer....
 Post subject: Re: security system
PostPosted: Thu Jun 17, 2010 10:31 am
You just had the tranny out and in.......seems like something there might be a good place to look.
Sounds like an electric connection has come undone.
Just a thought...
PostPosted: Thu Jun 17, 2010 5:47 pm
yes the passlock system which kills the fuel pump if anyone tries to spark the wires to start it. i you dont want to have a mechanic check it out i can show you what wire to cut underneath the dash to completely turn it off :whistle:
PostPosted: Sun Jun 20, 2010 1:38 pm
that sounds like the way to go.....
PostPosted: Mon Jun 21, 2010 4:23 pm
Just a thought...
I had the starting problem before the transmission was out... a couple days after I got it, I had let it run for several hours (while I cleaned all the crap from the back of it, looked like it been used for hauling landscaping materials in it.... after I let cool a little, I changed the oil, and went to start it again, and finally fingered the problem as the security system (after checking to see if I was getting spark, and spraying starter fluid into the air intake hose.) I changed the battery in the key fob... and viola... started again, a couple weeks later again, after backing it down to end of the driveway, and transferring my carpet cleaning machine from Safari to new Astro.... I pulled it into the back yard, and the next morning... wouldn't start again..... replaced the battery again... and still not starting.. although the key fob, still controls the power door locks fine, so its not a case of buying a battery that was dead... Stumped...... can smell gas after cranking it, so not a fuel issue, security light comes on, along with the other dash lights (which it didn't when I first got it and the check engine light didn't usually come on when I turned the key until it started, not starting....)
PostPosted: Mon Jun 21, 2010 4:29 pm
any thoughts, give me a call at (216) 789-5486 (Clean for Less, Carpet and upholstery Cleaning)
PostPosted: Mon Jun 21, 2010 10:49 pm
played with a little and as it happens some times, the incredibly obvious is sometimes the solution... looked closer and the coil wire was off..... #-o (doo) :whistle:
but thanks for the inputs.... now I can finish fixing my shelves in it, load up my hoses and chemicals and start using it to make money and let my wife have her Villager (quest) back...
PostPosted: Mon Jun 21, 2010 11:44 pm
well isn't it nice that the fix didn't take any money out of you pocket :supz:
Users browsing this forum: No registered users and 5 guests
