need help with radio
seaway10
Post by seaway10 »
how would i go about removing my nonfunctional radio and re-installing another of the same type in my 1998 astro thank's for now
chartman
Re: need help with radio
Post by chartman »
pop off the plastic around the dash and radio. It should slide right out i memory serves me. If you arent good with soldering, take the project to your local car audio shop. They could use the biz.
2001 Astro AWD w/cast iron headers/ Vortec 350 / 5" lift / 8" Rear lift (AirBags)/ 31" Bridgstone Dualer AT REVOS on Wagon Wheels / 3500HD calipers / 250 Amp Alt / someone stole my huge system !!
http://www.ancc.cc/chris/astro
seaway10
Post by seaway10 »
thank you for the tip, but it a 1998 don't relay want to give somebody 300$ for a radio will try to fix it myself just trying to get some tip on how to go about it again thank you
Cobra
Post by Cobra »
if you are switching in the same unit it will be simple plug and play
v8famvan
Post by v8famvan »
seaway10,
The removal process of the radio is a relatively simple process as the panel in front of the radio/HVAC control/instrument panel is just held in with clips. Once removed, the radio also just pulls out of the dash once the tabs on either side of the radio are pushed down to release them.
James from B.C.
1992 Safari - R.I.P.
GM Grand Master Techncian
seaway10
Post by seaway10 »
thank you so i don't have to worry the supposedly code that supposedly need to be delete and re-entered
v8famvan
Post by v8famvan »
If your replacement radio does have a code in it, review the information in this thread to unlock it. viewtopic.php?f=63&t=42
James from B.C.
seaway10
Post by seaway10 »
well i just finish replacing it and had no problem replace with one of the same type of radio and it work's for less then 10$ very happy thank's everyone for the support save me some major money and now have my radio back very happy
