Stereo Frustration
Crabnife
Stereo Frustration
Post by Crabnife »
Rainy Sunday. Trying to hook up my stereo. 2 12s an a 1000 watt amp.
Trying to get my power wire through the firewall without drilling holes.
Just doing a getto setup until I get 0 gauge wire.
Any advice would be great.
Re: Stereo Frustration
Fill in your sig with your van info...year, engine, tranny etc.
What year is your van? On my 98, I had used an existing hole with a rubber boot and cable running through to put a few wires in. After a while, you run enough wires back and forth, you will just need to drill a hole and put a rubber grommet in it. Then silicone it up.
Crabnife
Post by Crabnife »
Ah, sorry, for the mean time. 2000 Safari AWD
stomp13
Post by stomp13 »
When I did my stereo wiring, I ended up drilling a hole on the driviers side firewall. To the right of the brake.
99 Astro LS AWD. 200k. Overlands 2inch lift. No name 29inch LT tires.
