Adding an AUX input to your Delco Stereo
Someone
Post by Someone »
Delco Aux Plug (Finally!)
This is a diagram explaining the wiring to the remote-mounted AUX cassette or CD in many late-model GM vehicles...
You can use this input to feed the radio a signal from other outside AUX sources, such as MP3, mobile video, cellular, etc. You just need a couple relays!
This post will include the basic pinout for the plugs.
The diagrams below show the position of the wiring, here are the colors:
A - Blue >> ACC w/30-second turn-off delay
B - Gray >> Dimmer 12v-0v
C - Bare w/sleeve >> Grounded Signal Shield
D - Green >> Right Signal
E - Orange/Black >> Left Signal
F - Tan >> Audio Common (Thanks Jeff!)
G - Black >> Chassis Ground
H - Green >> Data Bus
J - Orange >> Constant 12v
Please note that there are two green wires. They are not interchangable!
SoundworksCarAudio has attached this image:
'03 VW Jetta TDI
'78 Vette 350 4spd
www.vehiclefleetsolutions.ca
k120189
Post by k120189 »
i hate to bring this up cause its old...but someone would u care to draw up a schematic? i was interested in putting an input for my guitar into my dash to use my van as one big amp like the new VW..and to add a stereo jack for the usual ipod hook up
--->2000 RWD 4.3L/4L60E ,3.43 gears.exhaust and throttle body mods.
...gone =(...
-->1998 kia sportage 3 inch lift 30 inch tires under repairs
midnighthunder89
Re: Adding an AUX input to your Delco Stereo
Post by midnighthunder89 »
Hello,
This is the only post i can find dealing with adding an aux input for an ipod to a stock headunit. Has anyone done this mod? Can anyone display a diagram of what is needed and how to wire it up?
99 sle awd safari
Another addition to cash for clunkers.
LaGrasta
Has thanked: 2 times
Been thanked: 3 times
Post by LaGrasta »
great post and diagram, thanks.
For me, as I had an aftermarket head unit, I used the RCA jacks for the remote CD changer. I bought a RCA jack to iPOD dock cable and it works great.
1998 Astro, 246,000 miles
K&N air filter
TruCool trans cooler
madslammer
Post by madslammer »
Are the diagrams the ones for the plugs?
How about the relays you mention?
Just got a little lost when you mentioned the relays. . . 8-[
'97 Astro 2wd, lowered 4" w/Belltech spindles and drop leafs.
'87 Astro 2wd, lifted, pretty close to 4" all around.
maing bus
Post by maing bus »
anybody else had luck with creating this plug in?
I want to replace that slug bug thing with Maing bus!
justice
Post by justice »
there are people on eBay that are selling modded factory radios for the Astros that do not have the theaft lock and have the AUX input already installed. If you get one from them its just plug and play to install it in place of your factory unit.
I was going to get one from them but i already had an aux capable head unit new in the box sitting at the house so i used it instead.
Current - 2004 Astro Cargo
Former
95 Safari (money pit - sold)
93 Astro Cargo (totaled)
92 Astro Conversion (sold)
87 Safari Shorty (sold)
Wiley
Post by Wiley »
Haha, how does this work if we want to do it ourselves, I dont think its been answered. Thanks
astroturf
Post by astroturf »
Wiley wrote:Haha, how does this work if we want to do it ourselves, I dont think its been answered. Thanks
Why sure it has...
This is a STICKY isn't it?
Oh Oh, Sorry, I just read thru this sTICKY, Not too sticky is it?
astroturf
Post by astroturf »
Let's give this sticky SOME STICK...
Click Here: http://db.tt/cXYRpOUp It's in my Dropbox.
It is a complete? wiring diagram for an 03 Astro Van. Don't think much of the basic stuff (radio) has changed.
Good Luck and use at your own risk. Note: File size is 6.75 mb
GRAB IT WHILE YOU CAN... I often move junk, and try to clean up my PC. :toimonster: :toimonster: :toimonster:
Bret Schmerker
Post by Bret Schmerker »
:whistle: What GM Part Number the nine-pin shell? I am currently considering three flavors of 1 Factory Radio Cat. No. 638.01007C AM/FM/Compact-Cassette receivers with Dolby Laboratories Noise Reduction Type B (all professional remanufactures of General Motors P/N 15757047 as used in the 1996-2005 Chevrolet Astro LS/LT and GMC Safari SLE/SLT/SLZ with Deluxe AM/FM/Cassette Receiver and Eight Speakers, RPO UL0) as upgrades from my current (as of December 2019) General Motors P/N 16180215 (as used in the 1996-2005 Chevrolet Astro base and LS and GMC Safari base and LE with AM/FM/Cassette Receiver and Six Speakers, RPO UM6). I've partially deciphered the Circuit Numbers as an aid:
A: 43 - 1.0 LBL >> +Vcc Radio ("HOT IN ACC OR RUN")
B: 8 - 0.5 GY >> Illumination
C: 150 - bare braided Cu >> Signal Shields
D: ??? - 0.8 DGN >> RT Audio, Line-Level
E: ??? - 0.8 OR/BK >> LT Audio, Line-Level
F: ??? - 1.2 TN >> Audio Common
G: 150 - 1.6 BK >> -Vss Power Common
H: ??? - 0.5 LGN >> Data Bus
J: 340 - 0.8 OR >> +Vcc Memory ("HOT AT ALL TIMES")
Mmusicman
Been thanked: 2 times
Post by Mmusicman »
Save yourself a lot of trouble!
Bluetooth FM Transmitter... ONLY $14!
I've bought 3 of these things already.. they work great!
Clear, powerful, amazing CD quality sound.
https://www.amazon.com/gp/product/B07LB ... UTF8&psc=1
PS: There are MANY to choose from.. but many of the similar models have issues.
This one highly rated and works!
PSS: This has an aux jack too, as well as plays USB and micro SD sticks
