02 heater circuit bank # 1 sensor 3
howso48
Post by howso48 »
02 heater circuit bank # 1 sensor 3 , 02 heater circuit bank # 1 sensor 3, is there any chance these could be faulty wiring, lose or corroded connection #-o :withstupid: , and also any help 8-[ as to where this sensor # 3 bank # 1 is as to location in the :rolleyes: system ??
v8famvan
Re: 02 heater circuit bank # 1 sensor 3
Post by v8famvan »
Bank 1 sensor 3 is the O2 sensor after the catalytic converter.
This code is usually caused by a defective heater in the O2 sensor. To check the wiring, check for power on the pink wire & ground on the black wire. If they are ok, the problem will be the heater in the O2 sensor.
Replace, clear codes & drive.
James from B.C.
1992 Safari - R.I.P.
GM Grand Master Techncian
