HI
I did a search, but did not find this code..
P1133
I had a "pop" and misfire. Van ran ratty.
Shut it off and when restarted, the van ran fine.
But, check engine light was on...
Used a tool and got this code.
P1133 - Heated O2 Sensor, circuit insufficent activity, bank 1, sensor 1
1.Is this the O2 sensor on the drivers side?
2. I should replace it?
thanks
bill
P1133 - Ho2S Insuffencet switching
Re: P1133 - Ho2S Insuffencet switching
Give this article a try.
http://www.engine-light-help.com/oxygen ... codes.html
Bank 1 is on the same side as cylinder 1. Sensor 1 is usually before the cat.
We need more info like year and engine code in your van.
I would check the wiring to that sensor first. Then try to remove it and see if it is carbon'd up. See if that works first. Bank 1 Sensor1 is definitely driver side first one from the engine.
LiftedAWDAstro wrote:We need more info like year and engine code in your van.
HI
1999
Where is the engine code?
Thanks !!!
bill
It'll be the 8th character in your Vehicle Identification Number (VIN) which you can see on the outside of your windshield (among various other places)
http://service.gm.com/dealerworld/vincards/
OK
Code W.
So, change the O2 sensor on bank 1 ?
thoughts?
thanks
bill
Code W.
thoughts?
thanks
bill
Typically when you get a code P1135 the sensor has degraded in its ability to properly switch thru the range the diagnostic expects it to go thru. So yes, replacement of the left front O2 sensor is recommended.
James from B.C.
1992 Safari - R.I.P.
GM Grand Master Techncian
v8famvan wrote:Typically when you get a code P1135 the sensor has degraded in its ability to properly switch thru the range the diagnostic expects it to go thru. So yes, replacement of the left front O2 sensor is recommended.
Thank you Sir !
