Why is the front diff so hard to put back in
sxfx
Post by sxfx »
So me and my buddy took 2 front differentials out of 2 awd astro vans know we tried all day to put the new 1 in but there is no way in hell its going in is there any trick or any help/advice you can give me would be greatly appreciated.
ihatemybike
Re: Why is the front diff so hard to put back in
Post by ihatemybike »
I did Grumpy's solo earlier this year. Didn't notice any real trick. Just used a floor jack and wiggled the diff till it went in place.
What mounting point are you having trouble with?
Put the long side axle tube up in first. It is then just a matter of twisting and turning until it goes.
sxfx
Post by sxfx »
Awesome thanks for the suggestion will try out tomorrow. I think my biggest problem is that I can get the bottom part into the mount, but its the top mount cause Im not sure how to clear the two metal bars that turn the wheels when spinning the diff upwards while in the bottom mount.
But I think I have to wiggle it in there first before putting into mounts.
sxfx
Post by sxfx »
Well I have no idea what was wrong with me on Saturday. I went under the car today around 12pm looked up and it all made perfect sense how to get it in there. GO figure.
Well anyways filled the trans and transfer case with dexron 6, and the front diff with synthetic gear oil, and she runs like a beaute.
Not really sure what was wrong with the old diff but I am glad everything worked out.\
Time to get some all terrain tires and maybe a small lift in the future :).
Thanks for all the help.
Post by mdmead »
Good job! Glad you got it fixed. :supz:
Cobra
Post by Cobra »
how long did it take to remove and install the front diff btw
sxfx
Post by sxfx »
Cobra wrote:how long did it take to remove and install the front diff btw
First time It took me about 2 hours, second time around 45 mins.
zuren
Post by zuren »
sxfx wrote:So me and my buddy took 2 front differentials out of 2 awd astro vans know we tried all day to put the new 1 in but there is no way in hell its going in is there any trick or any help/advice you can give me would be greatly appreciated.
sxfx - What issues were you having with those diffs.? I'm having an issue with mine that I'm trying to sort out.
