COOLANT FLUSH
- antispam: No
- How many wheels are on an Astro van? (4): 4
COOLANT FLUSH
HI, I'M A NEWBY TO THE FORUM AND WANTED SOME HELP ON FLUSHING MY COOLANT ON 2002 ASTRO, I CAN'T FIGURE OUT WHAT HEATER HOSE IS THE INLET OR OUTLET, PLEASE HELP.
PETER
PETER
- antispam: No
Re: COOLANT FLUSH
Hi Peter........Welcome to the site. It doesn't really matter which one you use. Either one will flush the engine. Remove the lower radiator hose and let the water run until it comes out clear.
- antispam: No
Re: COOLANT FLUSH
THANKS FOR THE FAST RESPONSE, I WANTED TO USE A PRESTONE FLUSH KIT AND IT SPECIFIES WHAT HEATER HOSE TO TAP, ALSO WHILE I'M ON IT WHAT COOLANT CAN YOU RECOMMEND. 2002 ASTRO
PETE
PETE
- antispam: No
Re: COOLANT FLUSH
Welcome Peter!
Please lose the caps lock.
IIRC, the inlet hose is the one that hooks to the intake manifold, and the return hooks to the pump on the suction side. I hope I have that right.
If you run the heater on a cold engine, you can feel the hotter hose as the engine warms, that is the inlet.
This is how I did mine, it is the only really good way if your van had Dexcool in it, IMHO. viewtopic.php?f=6&t=5199&start=0
- antispam: No
Re: COOLANT FLUSH
PLEASE don't use a Prestone Flush Kit. Cutting a line gives you one more place for a leak and the cold water from the household water supply will cause the t-stat to stay shut.
- antispam: No
Re: COOLANT FLUSH
Hey, welcome to the forum! Great people here with lot's of help. I agree, scrap the flush kit.
Just unhook each hose and jam a garden hose in and blast away, works great. If you really want to flush the whole system, unhook any and every hose and flush both forward and back. I think you'll find this cheap, easy and effective. Doing it even just once should last a long time before any need of it again.
1998 Astro, 224,000 miles
K&N air filter
TruCool trans cooler
K&N air filter
- antispam: No
Re: COOLANT FLUSH
stupid question perhaps.... can you pull the stat and then flush it with cold water? .. or when run, if the cold water warms up anyway .. wouldn't the stat open?CaptSquid wrote:the cold water from the household water supply will cause the t-stat to stay shut.
curious
Rob
current rides:
04 Mazda 6 V6 5spd
vans owned:
99 Astro LS Sept 08 ASV VOM
94 Astro LT
93 Astro LT
96 Astro LT AWD * parts van*
current rides:
04 Mazda 6 V6 5spd
vans owned:
94 Astro LT
93 Astro LT
- antispam: No
Re: COOLANT FLUSH
The Capt. is correct. Cold water will keep the t-stat closed. However, if you flush through one of the heater hoses the t-stat will not affect the flush provided the heater hoses are connected to the manifold and water pump. In order to flush the radiator you will have to remove the radiator hoses.
- antispam: No
Re: COOLANT FLUSH
If you're doing the flush, this would be a good time to spend $5 and replace the stat anyway, good insurance.
K&N air filter
K&N air filter
- antispam: No
Re: COOLANT FLUSH
+1LaGrasta wrote:If you're doing the flush, this would be a good time to spend $5 and replace the stat anyway, good insurance.
name's Steve
name's Steve
- antispam: No
Re: COOLANT FLUSH
Sorry, crash, but the water flowing through the engine isn't in there long enough to get warm. I did that on a 77 DJ5 and only managed to flush part of the system. It NEVER got warm.crash wrote:stupid question perhaps.... can you pull the stat and then flush it with cold water? .. or when run, if the cold water warms up anyway .. wouldn't the stat open?CaptSquid wrote:the cold water from the household water supply will cause the t-stat to stay shut.![]()
curious
I went to the hardware store and got the metal hose ends and a few worm clamps. I kept them in my tools until I got rid of the old girl (the N. Charleston PD took her away because they CLAIMED I was parked illegally. They hated sailors.)
- antispam: No
Re: COOLANT FLUSH
FYI-be careful about putting 40 degree water into a 150 degree engine. Sometimes physics wins.
viewtopic.php?f=58&t=9962
- antispam: No
Re: COOLANT FLUSH
That sounds SCARY
. Care to share the details?
