Hello,
I have a 95 Astro with a 343 rear end and was looking to upgrade for towing a 4k lb camper. One junkyard has a 373 for 300 drum to drum. out of a 98. Another yard says only 95's will fit. They have 4 vans but of unknown ratio's. I'll have to check them. They want 100 but I have to remove. What are the compatible years?
Thanks,
Rick
Compatible 95 Astro Rearends
Re: Compatible 95 Astro Rearends
The 98 will work with the exception of the possibility of having the rear wheel ABS sensors in your 95. I don't think they ran the rear ABS on the axle in the 95 vans. I think it was done in the VSS on the transmission or transfer case. You can look on your van to see if there is a wire going to each rear wheel. If not, the 98 axle will work great. Grab the 98's clamshell brackets when you get it as the mounts are just slightly different. If you can't get the clamshell you can use your stock one with very minor mods.
Any Astro or Safari rear from 85 to 2002 will work. You are better off staying with 1990 to 2002 as they have stronger axle shafts.
