It is currently Fri Feb 23, 2018 6:05 pm
Post new topic Reply to topic  [ 6 posts ]
 Post subject: Drivetrain noise when in gear
PostPosted: Thu Oct 12, 2017 8:54 pm
It may have been there all along, but I'm guessing not. It's a very faint "whoop" "whoop" noise which is rpm dependent, and is--I think--coming from the middle or rear of the van. If I'm motoring along on a quiet night below highway speeds I can hear it, but it stops if I shift into neutral and coast at the same speed. I'm guessing this eliminates the tires, but I wonder if the drive shaft turns when I'm coasting with my foot off the gas? I haven't yet checked for play in the drive shaft.
2001 AWD stock Astro
 Post subject: Re: Drivetrain noise when in gear
PostPosted: Fri Oct 13, 2017 1:59 pm
It could be a multitude of things. First off, yes your driveshaft will be turning. If your wheels are turning your driveshaft is turning. It seems your noise is load dependent. As in engine torque applied to your drivetrain dependent. Engine torque will induce loads on u joints, transmission bearings and so on that may cause your noise but only when under load. Good luck
1999 Safari SLE AWD
np236 transfer case
Torsen limited slip cast iron front diff
Torsen rear w/3.73's
2" body lift
S-10 rear leafs
Coming soon:
Skid plates
Rock rails
PostPosted: Sat Oct 14, 2017 3:27 am
Thanks. Maybe I'll start with the wheel bearings. Also, is it ever done that one starts a vehicle on a lift, tires in the air, and puts it in gear and accelerates to locate sounds?
PostPosted: Tue Oct 17, 2017 5:35 pm
Yes you can run a vehicle on a lift. Make sure it’s set well, make sure there is someone competent in the cab and make sure you pay very close attention to your surroundings while under a vehicle with rotating parts.
1999 Safari SLE AWD
np236 transfer case
2" body lift
S-10 rear leafs
Coming soon:
Skid plates
Rock rails
PostPosted: Sun Oct 29, 2017 2:52 pm
Thanks.
PostPosted: Sun Oct 29, 2017 11:01 pm
Captn. Crunch wrote:
Engine torque will induce loads on u joints...
^^ This would be my first guess.
Does the condition change when you go in and out of torque-converter lockup?
Users browsing this forum: No registered users and 6 guests
