replacing TC motor
replacing TC motor
My 2000 AWD is not engaging in AWD. I've been told the most common prob is the encoder motor so I bought one. In the instructions it said to clear atc codes before using. As you know, shops that have scanners for this are not open for the next couple of days which is my time limit. 1) Is this even important and if it is, how do I clear the codes and 2) how do I get that front driveshaft CV from TC without damaging any seals? My son is moving to Colorado the morning of the 26th and I have to get the AWD to work. Any input will be greatly appreciated. Thank You.
Re: replacing TC motor
I can't answer on clearing the codes except for reading the thread about swapping in a NP 233 electric shift t-case. There is something about clearing codes.
As for removal for the front driveshaft, you need to remove the shaft from the front diff. My 2005 is 4 bolts. Once that is loose, let it lay on the exhaust pipe and using a light hammer, tap on the driveshaft at the t-case end while pulling it off. It should pop right loose. No worries about a seal as the shaft never touches it.
Thank you, it sure felt like there was a clip in there or something keeping it from coming out from the Tcase . I'll try tapping it out. Then I can get that bolt out. With any luck, once I replace the tc motor, the AWD will work and the code will just go away.
Using a piece of hardwood I was able to tap the cv off of the output shaft far enough for the bolt to clear, popped in new motor and after a test drive up and down my snow packed road it was nice to feel that AWD kick in instead of just one wheel spinning going nowhere! While I was working on it I had removed the atc fuse hoping that might reset the codes, not sure if it worked but the service awd light is off. Now I gotta replace the passenger side door handle that broke right after test drive. Seems like some of these things were designed on a Friday just before 5pm. Thanks for the help and Merry Christmas!
You are welcome. Glad it's working. Merry Christmas to you too!
