4L60 cooling lines
howso48
4L60 cooling lines
Post by howso48 »
Can any body tell me which is the Hi pressure and low press side of the cooling lines at the transmission???? of the 4L60 transmission in my 97 Astro 8-[
MrJames
Re: 4L60 cooling lines
Post by MrJames »
Unless I am mistaken, the lower connection is the cooler feed, and the upper connection is the return.
I believe that GM had 4L60E's in the 1996 and up vehicles.
That is true at the radiator cooler. I would have to go to the garage to open the FSM and see what line is in and out at the trans. You could follow the lines from the cooler back. The top is the return back to trans.
