Driver Window
FROM HEADLINERS TO CARPETS, CUSTOM DASHES TO MOOD LIGHTING, IT GOES HERE.
Moderator: trybe13
CaptSquid
Driver Window
Post by CaptSquid » Thu May 29, 2014 12:00 am
With the advent of higher daylight temps (and the wonky ignition switch), the driver's window goes down nicely, but takes 10 - 15 minutes to shut. The Thermal Cutout keeps cutting out. HELP!
AstroWill
Re: Driver Window
Post by AstroWill » Thu May 29, 2014 2:14 am
You can take it apart and bypass the thermal cutout(at your own risk), or replace it with a new unit.
Re: Driver Window
Post by LiftedAWDAstro » Thu May 29, 2014 11:07 am
I would pull the interior panel and see if the window has any points that can be lubed. Then, if you can, put an ammeter on the motor wires and see what kind of current the motor draws. If it isn't too much, replace the thermal cutout.
CaptSquid
Re: Driver Window
Post by CaptSquid » Thu May 29, 2014 11:09 pm
Cross your fingers! Thx.
