factory tach??
FROM HEADLINERS TO CARPETS, CUSTOM DASHES TO MOOD LIGHTING, IT GOES HERE.
moparnut
factory tach??
Post by moparnut »
is their an option for a factory tach? or can you add a new cluster from a ??? s-10 maybe?? any info would be great.
thanxx.
moparnut
Re: factory tach??
Post by moparnut »
sorry, its for a 1997 astro.
ihatemybike
Re: factory tach??
Post by ihatemybike »
No factory tach. Both my ScanGaugeII and UltraGauge are capable of displaying RPMs.
Aaron
Prev Astros:99,97,00,94,87,86
moparnut
Re: factory tach??
Post by moparnut »
Can u put in a cluster from another vehicle that has a tach like a truck or a blazer?
CaptSquid
Re: factory tach??
Post by CaptSquid »
Sure can. Make sure it's the same shape. If it's a non-mechanical speedo, it's all plug-n-play.
Mike, Billings, MT, 'MERICA!
98 AWD Stro LS
93 Suburban Silverado 4x4
rjfalski
Re: factory tach??
Post by rjfalski »
I found this at autozone... fit's perfect
2 1/2 Tach.
2 1/2 Tach.
Re: factory tach??
I know this is an old thread...but...When I picked up the t-case parts I also picked up the dash cluster from the 2000 Blazer. A quick measurement shows it should be very close to fitting if not a perfect fit. Does anyone have the pinout of the Blazer and my 2005 Astro? The connector wire colors don't match between the 2000 Blazer and the 98 Astro/Safari vans. The colors don't match but maybe the wire functions are the same?
Found the 2000 Blazer pinout...just need the 2005 Astro's.
Re: factory tach??
rjfalski wrote:I found this at autozone... fit's perfect
Thats what I did too. Fits well with that style of speedo on those old style cluster.
Not sure how it would work on the newer round dial speedo though. Never tried.
I can say that my five speed van has an OEM connector for a tach, coming out from the distributor wire harness.
But I dont think they ever actually offered one.
Re: factory tach??
My old 98 SPB had a tach wire at the coil or ICM...can't remember where and I put a tach into a dual A pillar pod. On the 96+ clusters I don't think a tach on the steering wheel will work.
