Driver and passenger windows go up very slowly, if at all
FROM HEADLINERS TO CARPETS, CUSTOM DASHES TO MOOD LIGHTING, IT GOES HERE.
trip_south
Post by trip_south »
The driver and passenger windows both go down fine but usually when trying to shut the window it starts going up very slowly and then stops after a second or two. Waiting 15-45 seconds allows for another try at shutting the window, usually resulting in the same second or two of movement and then stoppage. I figure the motor/regulator may just be getting tired after 100K miles but I'm not sure what exactly to replace. I see they sell window/regular combination units but I'm not sure if I need both changed out. Is there some thermal regulator that I'm testing every time I try shutting and that might be bad too?
Thanks for any advice!
99 Safari AWD -> 4WD slowly Update: Auto 4wd, 2Hi, 4Hi work, no luck with shifting to 4lo
Re: Driver and passenger windows go up very slowly, if at al
Post by Smiliesafari »
I'm guessing that nothing on the regulator has been lubed since the van left the factory. The factory lube gets hard after all these years. A good cleaning and fresh lube would do miracles for the operation of the windows.
trip_south
Thanks for the tip, I'll give it a try.
LaGrasta
Has thanked: 2 times
Been thanked: 3 times
Post by LaGrasta »
I've replaced both of mine. I spent $20 each, shipped from eBay and they have been working perfect for a few years now. As for replacing them, remove the door panel, drill out the rivets and screw in the new ones, very easy.
My Dad has a Chevy car and I convinced him he could do it too and same result, cheap and easy.
1998 Astro, 246,000 miles
K&N air filter
TruCool trans cooler
