blower motor
HVAC, heating, cooling, air handling. Anything air temp related.
fsnrod
blower motor
Post by fsnrod »
How do replace the blower motor on a 2000 astro it looks like it's under a plastic shroud do you have to take off the fender to work on it?
Re: blower motor
If you read the writing on the shroud it mentions cutting parts of it with a utility knife. Do this and then it comes out by removing a few screws. You will need to remove the washer fluid/ antifreeze over flow bottle first.
Has thanked: 44 times
Been thanked: 24 times
Re: blower motor
There's also plenty of info here in the forum. Just hit the Search button in the upper right of your window. Best of luck.
