How do I know which compressor I have, and does it matter?
bobenhotep
Post by bobenhotep » Mon Jun 11, 2012 1:55 pm
How can I tell if the compressor is a H6 or a HT6? Does it matter which I use, or is one for no rear air and the other for rear air? I have a 2000 astro with rear a/c if that helps.
2000 Astro 2wd
Re: How do I know which compressor I have, and does it matte
Post by Smiliesafari » Mon Jun 11, 2012 3:17 pm
When I replaced the compressor on my '96 there were no such designations. I used a Delphi.
LaGrasta
Post by LaGrasta » Mon Jun 11, 2012 8:31 pm
Even with front and rear a/c, there is only one compressor. I'm not certain the two distinctions you mentioned though.
1998 Astro, 224,000 miles
K&N air filter
TruCool trans cooler
lockdoc
Post by lockdoc » Tue Jun 12, 2012 12:52 am
I'm not sure what the difference is but a 96-05 used an HT6.
Current:
01 AWD - Stock
98 AWD - Stock
Past:
94 RWD - 350 V8 - sons van
92 RWD - stock - sons van
93 RWD Shorty - project
89 RWD Shorty - parts van
bobenhotep
Post by bobenhotep » Tue Jun 12, 2012 3:23 am
Groovy, an HT6 it is, then. It is slinging ac oil out of the front seal, so now I can get the ac going again, and have it able to actually hold charge.
2000 Astro 2wd
