AC blowing warm/hot air | Compressor cycles on/off (VIDEO)
ANYTHING TO DO WITH CHANGING THE AIR TEMP INSIDE YOUR VAN.
kkamakasi
Re: AC blowing warm/hot air | Compressor cycles on/off (VIDE
Post by kkamakasi » Wed May 18, 2011 8:15 pm
astroturf wrote:Try http://www.gmpartsgiant.com
Still no illustration but it does have a "See if this part fits your car" function and it does fit my car so I guess this HAS to be part...
Thanks fellas!
astroturf
Post by astroturf » Wed May 18, 2011 8:21 pm
Once you enter your van info, find the parts section. It will have a listing of part numbers. Click on the top of the screen where it says more info. A PDF of the parts will open.
Enjoy, Jim
astroturf
Post by astroturf » Wed May 18, 2011 8:26 pm
astroturf wrote:Once you enter your van info, find the parts section. It will have a listing of part numbers. Click on the top of the screen where it says more info. A PDF of the parts will open.
Enjoy, Jim
Sorry it is at the bottom of the page after you select a part:
http://www.gmpartsgiant.com/Page_Produc ... =TM0930801
more info button
kkamakasi
Post by kkamakasi » Thu May 19, 2011 1:15 am
Enjoy, Jim
more info button
You're the man JIM!
I confirmed the part and is on its way here. Thanks again.
astroturf
Post by astroturf » Thu May 19, 2011 1:17 am
Hey, No Prob...
Hope it works out.
kkamakasi
Post by kkamakasi » Mon Jun 06, 2011 8:56 pm
UPDATE:
I got the part replaced and evac/recharged the system and everything is working now.'
Has anyone else experienced anything like this where the dipstick tube heated up causing the AC hose to melt and leak refrigerant?
Seems like a design error because once I installed the new hose, it was still touching the dipstick tube so I had to get some of those plastic crinkle-style wire protectors and put it around the dipstick tube where the AC hose made contact.
timelessbeing
Post by timelessbeing » Mon Jun 06, 2011 9:13 pm
That sounds unusual. Maybe the tube got bumped and it's contacting your exhaust?
kkamakasi
Post by kkamakasi » Mon Jun 06, 2011 9:22 pm
So it's not normal for the AC hose to be touching the dipstick tube when you remove the doghouse?
