Blower motor
Re: Blower motor
Post by Smiliesafari » Tue Nov 06, 2012 8:31 pm
Nice.....that will help a lot of people. Thanks for posting.
thegreenmachine
Re: Blower motor
Post by thegreenmachine » Fri Nov 09, 2012 12:03 am
Had the same problem. Replaced the blower motor and then the resister
Pack. It is located under the blower and has the harness coming out (I think )
Gm redesigned the resistor pack to make it " better". So some
Modification to where the pack screws in. 7mm or 5mm I think
A dremal or a hack saw blade cut in half with tape wrapped around
It works good. Template is in the kit.
Btw...... My van also directs hvac to the floor when accelerating.
Only on ac and when it's on 3. If we count all the way to the
Left 1.... Hasn't done it since the end of the summer. :cheers:
2003 Chevrolet Astro 4wd np233c transfercase 245/75/16 ETS Trailermaster tires
Previous:
1995 Safari AWD (death by torsion bar. a.k.a. "the final straw")
1999 Safari AWD ( death by tree x2 )
1997 safari rwd cargo ( sold @ 450,000+ km )
LaGrasta
Re: Blower motor
Post by LaGrasta » Sat Sep 12, 2015 2:05 am
I just replaced both my resister pack and blower motor and it didn't change my situation. It was working on high only, now nothing. I'm suspicious of the new resister pack, maybe a dud?
In another thread it mentioned a fusible link as well as a grounding lug, where are those?
any suggestions or test to try?
1998 Astro, 224,000 miles
K&N air filter
TruCool trans cooler
AstroWill
Re: Blower motor
Post by AstroWill » Sun Sep 13, 2015 6:29 am
thegreenmachine wrote: Btw...... My van also directs hvac to the floor when accelerating.
I would replace all of the rest of the vacuum lines while you are at it. If it's dependent on engine load, it's going to be a vacuum problem.
Edit: Edited to add quote.
LaGrasta
Re: Blower motor
Post by LaGrasta » Mon Sep 14, 2015 4:25 pm
it must be the switch… after a tap on the dash, everything works perfect.
K&N air filter
