not enough heat
rooster4
not enough heat
Post by rooster4 » Sat Jan 11, 2014 6:23 pm
my 98 astro temp gauge always reads 130 150 degrees and although the heat is warm its not as hot as my other cars. Is a new thermostat in my future?
1998 astro
2006 cobalt
VanGoGo
Re: not enough heat
Post by VanGoGo » Sat Jan 11, 2014 6:42 pm
I would get a 'second opinion' on what the factory gauge reads, my factory gauge also shows the temp range you mentioned, but my Ultra Gauge shows temps around 180 to 190.
"BOYCOTT AUTOZONE!"
Re: not enough heat
Post by LiftedAWDAstro » Sun Jan 12, 2014 12:25 am
I too had a faulty gauge in my 98. It read much lower than actual. I had it read with a scanner at the time and found the engine to be right at the thermostat setting. If it isn't blowing nice hot air, you may need one. It is good maintenance to change them and the anti-freeze every once in a while.
