Over heating problem please help!!
Re: Over heating problem please help!!
Are you relying on the temp gauge only or have you hooked up a mechanical gauge to verify your gauge is correct ?
VIDEO
VIDEO
Did this problem exist before the work (intake manifold gasket, thermostat and temp sender) or started after ?
Mrjames- before I replace the intake gaskets and thermostat and sender my van didn't have a thermostat in it so it ran cold until I started to climb a hill then it would climb up to the yellow. After all that work it would sit at an idle an over heat but if you started driving it would cool down. Soooo, I replaced my radiator and cap last night and it is
Running cooler then I've seen it run. I still have not drivin it enough up and down some hills and I'll know if it's working or not! And I believe my water pump is healthy because it is not leaking yet. I'm hopeful this radiator has solved my issue!!!
1991 Astro RWD EXT w/187000 miles
1991 GMC safari RWD shorty w/151000 miles
Runs off of Bacon!
The revolution of the Maing Bus!!!
Runs off of Bacon!
I believe the radiator has fixed my problem. I'm wondering why I keep flashing a code 32 though?
Runs off of Bacon!
Runs off of Bacon!
That is an EGR code. What engine do you have? There are two different styles of EGR valve. Check for the connections, and the vacuum lines being hooked up.
Scott
Scott
I've got the 4.3 vin z I think. I only say I think because I have recently learned its not the original engine but it is a 4.3 and it has the transmission out of a 93 Camero. I'll pull the dog house tomorrow but the EGR valve will be on the drivers Side under the dog house right?
Thanks,
Derek
Thanks,
Derek
Runs off of Bacon!
Runs off of Bacon!
