My van heats up quickly, and the gauge usually stays right in the middle, leaning toward the high end. Lately, though, it's been fluctuating pretty bad (I can watch the gauge go up and down going down the road), and it seems to be running hotter than usual. I checked the coolant to find that it was really low. I filled it up the rest of the way with water, and the next day it was a bit low again. I just did an oil change, and found no water in the oil but I do have some on the front of the engine right where the hose from the radiator goes into the top. The coolant seems to be coming from just below where the hose mount bolts in. I think it might be leaking from there but drying up towards the top. Someone suggested that I replace my thermostat. This is really making me nervous here... Does anyone have any advice?
Btw, I'd have pics but my SD card reader stopped working and I can't get them off my phone right now. I'll have to transfer them to my other phone with USB connectivity and get them that way. Maybe tomorrow I can have them. I hope somebody can help me without pics, though.
Also, it has the regular green coolant in it. In my searching I found that yellow coolant apparently causes leaks.
Odd temperature problem
Jake
Old rides (earlier to later)
Re: Odd temperature problem
Yup, sounds like you need to drain it down, pull the upper hose off, remove the thermostat housing and either replace the seal or hose or whatever is leaking. Might as well do the thermostat while you are there. Make sure you put antifreeze back in.
Any recommendations on the type of antifreeze?
Jake
- Has thanked: 45 times
