Is this a GM Problem?
I have owned many astro/safari models and 3 S-10's and all of them have have had a non functional engine temperature gauges. I would like to have both the one in my Safari and the one in my S-10 4x4 working so if anyone has any idea as to what the problem may be please let me know. Thank You, Mark
Re: Is this a GM Problem?
Mark,I have owned two S10's and own three Astro's.None of them has issues with the temp gauge.I suggest in any case you would need to treat each one-one for one.
Temp gauge sender is usually mounted in the drivers side head. Typically has a single green wire going to it. Grounding it should get some response from the needle of the gauge.
James from B.C.
1992 Safari - R.I.P.
GM Grand Master Techncian
ok ty
