Coolant Temperature Fluctuating Wildly
DerekBell
Post by DerekBell »
At cruise, the coolant temperature holds relatively properly. In stop and go traffic, it will frequently dip below normal and heater starts blowing cool. Occasionally it will dash towards the redline, 'check gauges' light illuminates momentarily, then settles back into the normal range.
I'm hoping that it is only the thermostat (192k miles, and I think it's the original), and will be installing a new one this weekend (parked until then).
Might these symptoms point to possibly other, bigger issues?
2000 AWD, 195K miles
Stock 3.42, one legger
Biltsteins in front, Ranchos in back
Helwig Rear Anti-sway
HID + Clear Lenses
ihatemybike
Re: Coolant Temperature Fluctuating Wildly
Post by ihatemybike »
That's usually a sign of low coolant.
Aaron
Prev Astros:99,97,00,94,87,86
leadtrombone
Post by leadtrombone »
x2 on low coolant. Check your levels and work the air bubbles out.
Open the radiator cap and top off. Run the engine with radiator cap off. when the engine gets warm and the thermostat opens and the coolant cycles through all the spots you will probably see some air bubbles percolate up through the radiator.
as the weather got cooler i noticed my heater didn't seem to heat. Did that above and after a couple of bubbles the heat started pouring out the vents.
any better ideas.. For that matter is there a bleed valve in the system somewhere???
good luck
1999 Safari SLE. Stock. Proud owner since May 2010. So far I love it..
P1050479 by leadtrombone, on Flickr
The old cars - my progression to here (most recent first)
1996 Honda Passport
1988 BMW 320i touring
1989 BMW 520
2005 Chrysler Sebring Convertible
2002 Dodge 1500 Quad Cab
1989 BMW 320i
1990 Toyota Tercel EZ
1991 Mitshubishi Mirage
1970 Mercedes Benz 250 Saloon
Kabey's Van
Post by Kabey's Van »
There is no bleed valve, but I agree with the trombone player and the guy that hates bikes.
I would change the t-stat if it's original. Then top off the coolant level.
DerekBell
Post by DerekBell »
Turns out that I have a coolant leak up near the intake manifold. I had checked the coolant level not too long ago, and it was good. Therefore I thought that I was having another issue. Checked it again as per the input on this page, and sure enough - low.
I wasn't having the obvious signs of a leak, like a pond in the parking spot, 'cus it was only seeping out while under way and flowing over the top of the engine. Thanks for all that folks!
HID + Clear Lenses
reaper
Post by reaper »
Kabey's Van wrote:There is no bleed valve, but I agree with the trombone player and the guy that hates bikes.
LOL :partyman:
90 Astro Cargo V-8
90 Artro RS - V-8 Now running!
& a bunch of tractors
"there's nothing like a V-8 Polluting the Environment"
ihatemybike
I did Green's intake manifold gasket last winter. Not to terrible to do. Having a garage to do it in helped.
Aaron
