Okay, I've got an 03 Astro with about 108,000 miles on it. It's got Dexcool, but it's my understanding that there were two different types of Dexcool. Apparantly there was the bad stuff that ate head gaskets and got GM sued. But earlier, outside of this particular forum, someone was talking about a newer Dexcool that didn't do that.
So, did this newer Dexcool exist, was it used on 03, and is it actually safe for my gaskets?
And a fourth question...with 108,000 miles, is it even worth switching?
2003 Astro with Dexcool
2007 Chevy Cobalt
Re: 2003 Astro with Dexcool
At over 5 years of age and 108,000 miles it is time for a flush whether or not it is still "considered" to be good by GM. For a measly $20 why take a chance? I would just drain out the system by removing the lower rad hose and letting as much drain out as possible. Then I would re-fill with fresh coolant and plan to do the same again in a couple years. This method won't completely flush the system out but it will give a majority of fresh fluid.
- Has thanked: 2 times
I agree, it's time. After you disconnect and drain, stick a hose in there and flush it as well.
If this is a long term vehicle for you, spend an extra $50 and swap the hoses and belt now as well, even a thermostat. This will further your success in flushing it as well as removing any future weak links that may decide to show up.
1998 Astro, 246,000 miles
K&N air filter
TruCool trans cooler
K&N air filter
