I just purchased a mint condition Astro Van. It looks looks it has the red coolant. Has anyone had any problems with this type coolant? Would it be beneficial to change it more often than the recommended interval? The van has only 64,000 miles on it. It's a 2000.
I appreciate your help!
John
Do I need to change from DEX coolant?
Re: Do I need to change from DEX coolant?
the general concensus around here is to flush out the dex completely and to switch over to the regular green stuff......
1995 Black LT AWD
2000 Ninja ZX-6R
2000 Ninja ZX-6R
Oh hell yes!! Get the DexCool stuff outta there just as quick as possible. Flush the overflow bottle, and waste a whole lot of water to get every drop of that 'stuff'.
You'll find that there are not many folks that have nice words for DexCool.... except gasket manufactures.
http://www.consumeraffairs.com/news04/2 ... xcool.html
http://www.girardgibbs.com/dexcool.html
http://www.sancarlosradiator.com/dex-cool.htm
Indy, all the horsepower you could ever imagine in one place...
Indianapolis 500, MotoGP, 400 at the Brickyard, NHRA US Nationals.
1991 Safari GT, 'B' motor, factory 4.10's. Original Owner !!!
is flushing the dex out something anyone can do themselves? or, is this something that a rad shop should do... with proper flushing machines... ? .. what about the heater core?
Rob
current rides:
04 Mazda 6 V6 5spd
vans owned:
99 Astro LS Sept 08 ASV VOM
94 Astro LT
93 Astro LT
96 Astro LT AWD * parts van*
current rides:
04 Mazda 6 V6 5spd
vans owned:
94 Astro LT
93 Astro LT
If you don't have the dreaded DexCool sludge....
On a cold engine, drain the DexCool for proper waste disposal. Place the temp lever(s) to 'ON' & 'HOT', and stick the hose in the filler neck for the radiator & leave the drain petcock open. Scrub out & rinse the overflow, (puke), tank.
Have a beer, take your time...
Pull the thermostat housing, (you were gonna change the thermostat anyway I hope), and stick that same hose in there....
Have another cold one, again taking your time....
Put it all back together/close it all back up, fill with 50/50 and run engine & heater(s), to burp any air bubbles out, fill the overflow bottle to the 'FULL' mark. Once the engine starts to warm, the coolant will tend to overflow the fill opening, that's the time to put the cap back on, and allow to idle for about 10 more minutes. Check for leaks !!!
Kill a couple more of those brews while cleaning-up and putting away everything. Two beers enjoyed responsibly is just about the right amount of time for the system to cool off and draw back from the overflow bottle.... just top off the bottle to between the 'COLD' & 'FULL' marks, and watch it for a few days. Top up as necessary.
Sit back, admire your handy-work & complete the afternoon with the rest of that 6-er.
Oh yeah, I strongly recommend using distilled or de-mineralized water available from the local grocery store... less than a buck a gallon, leaves no minerals/residue in a cooling system and any leftover you can use in your iron when you are doing laundry. (It's tips like this that keeps my wife happy when I make a mess. )
Thanks for the replies, folks!
Looks like there are unanimous opinions regarding DEX.
2000 White Astro Van 2WD
64000 miles
Everything stock
64000 miles
Everything stock
- Retired
Like they said, flush the orange and install the green.
Thats the quote my boss always says regarding Dexcool.SoCalli V8 wrote:flush the orange and install the green.
1991 Chevy Astro Extended- Stock 4.3
