what is this part called that's leaking coolant?
crash
Post by crash » Sat May 17, 2008 2:22 pm
normally, I'd post a pic and circle the problem LOL .. I'm at work and don't have my camera. there is an inline kind of vacuum looking thing on the heater hoses of the 93 van. under it, connected to it there is a metal rod that seems to have something to do with accuating .. I'm guessing something to do with the heater control. welll.. It's leaking coolant...
anyone know what the name of it is ?
AND... all that being said.. could this effect the van to be running hotter than normal? I was just about to change the t-stat and I saw where this thing was leaking....
thanks
Rob
ps. sorry for no visual 8-[
Rob Image
current rides:
04 Mazda 6 V6 5spd
vans owned: Image
99 Astro LS Sept 08 ASV VOM
94 Astro LT
93 Astro LT
96 Astro LT AWD * parts van*
Jim in Indy
Re: what is this part called that's leaking coolant?
Post by Jim in Indy » Sat May 17, 2008 2:52 pm
Is it just a few inches from the heater blower motor? If it is, it sure sounds like the heater shut-off valve. There should also be a vacuum line attached to it. The little seal that seals the actuator rod ain't doing it's job anymore, and you have to replace the assy as it's a non-serviceable POS.
When you select the temp high, or low by the dash control, this valve actuates open/closed to allow coolant to flow thru the heater core. Any leak that allows a pressure loss in the system will cause a slight increase in temp in the cooling system. Since ya gotta dump some coolant out to change the heater shutoff valve, I'd do the thermostat and flush the system too.....
Hope this helps.
Indy, all the horsepower you could ever imagine in one place...
Indianapolis 500, MotoGP, 400 at the Brickyard, NHRA US Nationals.
1991 Safari GT, 'B' motor, factory 4.10's. Original Owner !!!
crash
Post by crash » Sat May 17, 2008 2:56 pm
that would be the item ... thanks so much for the info and tips Jim
Rob Image
current rides:
04 Mazda 6 V6 5spd
vans owned: Image
94 Astro LT
93 Astro LT
crash
Post by crash » Sat May 17, 2008 3:04 pm
Hey Jim.. is this for front and rear heat or rear only? I can only find one listed for rear bypass in my lookup at work.... not cheap either. looks like a trip to the wrecker is in order on tuesday
Rob Image
current rides:
04 Mazda 6 V6 5spd
vans owned: Image
94 Astro LT
93 Astro LT
Jim in Indy
Post by Jim in Indy » Sat May 17, 2008 3:15 pm
On my 91, the valve up by the blower motor is for the front heat only. My rear heat is controlled by a separate valve down on the right frame rail, almost a straight shot from the center spark plug on the right bank....
Jim in Indy
Post by Jim in Indy » Sat May 17, 2008 3:20 pm
SoCalli V8
Post by SoCalli V8 » Sat May 17, 2008 3:37 pm
For that cheap price buy a new one, these plastic parts and the o-rings inside always go bad.
tbhager94
Post by tbhager94 » Sat May 17, 2008 5:54 pm
i have a good one off my 94 if ya want it .
2000 chev blazer 4x4
If its got tits or wheels, its gonna give you problems!
im sure we all know the #1 junk yard rule if it fits in your pocket its free.
crash
Post by crash » Sat May 17, 2008 7:22 pm
thanks guys... even though there wasn't one in my lookup by application... that link that jim posted helped a great deal. i was able to cross the number to a cooling depot # which my warehouse had one in stock. so I scooped it... my cost was less that $25.... as mentioned... for that price better to go new after going through all that coolant and effort to pull the old one.
Rob Image
current rides:
04 Mazda 6 V6 5spd
vans owned: Image
94 Astro LT
93 Astro LT
