r12 to r134a retrofit...
Radiator, thermostat, water pump, antifreeze, etc.
Jinmajay
Re: r12 to r134a retrofit...
Post by Jinmajay »
Come by the house and I will fill it up for you! I stocked up in 95 and have been carting it around the country with me.
Of course, you will have to help me on my project van... #-o
The Tran man http://jayjensen.shutterfly.com/action/
1994 AWD GMC Safari, V8 truck van project
1998 2WD Astro
1999 AWD Astro
safariobsession
Post by safariobsession »
Good thinking back in 95! How far of a drive from southeast MI? Anything over an hour drive and i might as well get the EPA certification and buy the r12 on ebay myself, based on gas prices, haha!
Van sold April 2009 -->
Image Image
Current Mods:
Diamond-Cut Headlights.......................Clear Corners.....
Gloss Black Wheels......P235/70-15 Firehawk Indy 500 tires
Pioneer CD/MP3 Player.....800W Legacy Amp.....Two 10" Sonys
Dynomax Super Turbo......SunPro Tach......GMC Truck Badged
Heated/Cooled Center Console......750 Watt Inverter with Custom 120V outlet
LaGrasta
Has thanked: 2 times
Been thanked: 3 times
Post by LaGrasta »
I recently inherited a 1990 Ford Taurus with a dead R-12 system. A professional mechanic friend of my Dad's in AZ converted my Dad's 1978 Chevy van to R134 really cheap and said he'd do the same for my Taurus. When asked what parts are needed, he said none to my surprise. He said he only cleans the entire system and recharges with R134. Can this be correct? My Dad said it's been two years since his 78 was done and it works well, even in 115°+ AAZ temps.
1998 Astro, 246,000 miles
K&N air filter
TruCool trans cooler
Rebel
Post by Rebel »
Have 4 cans of R-12,,,anyone have a need for these ?
VIDEO
s10-den
Post by s10-den »
how much Rebel?
On the other hand, I have converted several cars to 134a, will freeze your butt off here in Florida, so it cools just as good as r12 if not better
94 Astro cargo EXT----Bought specifically to mod!!Will be tbi 350 v8 and new front end conversion
Done so many v8 s10's their old news
COMP
Post by COMP »
the R-12 i have is a investment :D
Jim in Indy
Post by Jim in Indy »
If the long-chain chlorine atom was so 'bad' for the ozone layer.... then the EPA Nazi's would have outlawed swimming pool chemicals also. Think about all those pools, in the sunshine, evaporating, laden with, you guessed it.... the same basic chlorine atoms that make up R-12 !!
A pile of dung is a pile of dung, no matter what the latest junk science says.
Indy, all the horsepower you could ever imagine in one place...
Indianapolis 500, MotoGP, 400 at the Brickyard, NHRA US Nationals.
1991 Safari GT, 'B' motor, factory 4.10's. Original Owner !!!
CaptSquid
Post by CaptSquid »
LaGrasta wrote:I recently inherited a 1990 Ford Taurus with a dead R-12 system. A professional mechanic friend of my Dad's in AZ converted my Dad's 1978 Chevy van to R134 really cheap and said he'd do the same for my Taurus. When asked what parts are needed, he said none to my surprise. He said he only cleans the entire system and recharges with R134. Can this be correct? My Dad said it's been two years since his 78 was done and it works well, even in 115°+ AAZ temps.
You'll need a new dryer, a new oil charge, and a new orfice tube. Oh, yeah, the new connectors, too.
sfeaver
Post by sfeaver »
It the system still works, then I think youe easiest way is to get some real R12 and top it back up. You used to be able to take an online test for 20 bucks to get your EPA card to buy it. Doing a proper retrofit will cost more than the couple of pounds of R12 you will need.
I retrofitted an 89 Buick Lesabre a couple of years ago, do everything right, complete flush, new drier, new condensor etc. Wasnt good enough for me. Its back on R12 and will blow real cold. A system designed for R12 should run R12 if you can get your hands on it.
Scott
