I believe I have a leak at this thing but I have no idea what it is called to replace it. hopefully you guys know and can help me out. It looks like some kind of vaccum piece but I'm not sure. The hoses come from the water pump to the heater core.
any help you be great.
Thanks!
what is this part called?
Re: what is this part called?
Thats your heater control valve, you can get them from O'Reilly or Autozone. very reasonable, I just changed mine.
1993 Safari
Lowered
Shaved
Building my 350 and 400 turbo
all old school
Lowered
Shaved
all old school
- Retired
Yup, heater control valve they leak after a while......
I took mine out compleately and put a slicer pipe in, the only thing it dose is shut the water off to the heater core when you turn the temp down. I havent noticed any diff in heating OR cooling myself.
93 GMC Safari SOLD stilll see her drivein around every so often =/
I'm not sure what year those valves were added, but they weren't on my 89 or 88 Astros.
Rob Shaver
It is on my '90 and was replaced long ago.SafariRob wrote:I'm not sure what year those valves were added, but they weren't on my 89 or 88 Astros.
It was working correctly but was a drippin'.
I was told getting my beauty sleep was a waste of time.
1990 Astro (Z motor) mostly original @ 343,584 miles (552,944.8488960001 Canadian) (03/2008). Bad startup puff. Starting to spray for skeeters. Gone 06/07/08.
1993 Astro with a bad W motor. Parked next to a chicken coop in Talking Rock GA
I'm 'tween Canton and Holly Springs (North NorthWest of Atlanta GA)
I haul bottled water everyday- between 500 and 2500 pounds (226.796185 and 1,133.980925 Canadian) INSIDE the van.
Yeah, about every 6 or 7 years that seal goes away....
Indy, all the horsepower you could ever imagine in one place...
Indianapolis 500, MotoGP, 400 at the Brickyard, NHRA US Nationals.
1991 Safari GT, 'B' motor, factory 4.10's. Original Owner !!!
That's strange,,my 89 had one but ditched it and installed a valve that I shut off in the summer.
VIDEO
VIDEO
