electric fan thermostate switch
TheChopFather
Post by TheChopFather » Mon Feb 11, 2008 1:54 am
I just picked up an electric fan for TW what i want/need is the electric fan thermostate switch that turns on and off the fan what have you v8 guys used? I really dont want to just use a switch or have it power on and off with the keyswitch...
ISN'T HE SO SEXY IN HIS PRETTY WHITE DRESS???LOL
91AWDAstro
Re: electric fan thermostate switch
Post by 91AWDAstro » Mon Feb 11, 2008 1:59 am
This may be over kill for one fan, but I used the SPAl PWM controller on my dual setup. It was easy to install and I like the fact that it runs the fan at low speed most of the time. Keeps the noise down.
http://www.spalusa.com/fans/automated/a ... anpwm.html
Chris
91AWD 350
HPbyStan
Post by HPbyStan » Mon Feb 11, 2008 2:51 am
On my "98 Astro with a '99 LS1 I used stock dual radiators from a '97 Z28 Camero as well as the Cameros dual relays. Of course on this deal the LS1s computer was used and had a port to run the relays.
'04 White AWD Astro cargo
'00 Astro / El Camino
'61 BSA Super Rocket
peter
Post by peter » Mon Feb 11, 2008 8:49 am
http://www.flex-a-lite.com/auto/html/vsc.html
Only thing is that I'd install the probe in the head rather than the rad fins. I found too much of a temp inconsistency until mounting in it the head. Easy enuf to do using a 1/4" plumbing compression bushing/fitting.
"Just keep swimming..."
97' 4wd Safari
ZZ 502 Ramjet
4"L"80E/NP241C
Ford 9"
Kinky is using a feather.
- Thomas Jefferson
