Radiator Fan Clutch choice
Snowgeek
Post by Snowgeek » Wed Jul 18, 2018 3:34 am
Howdy folks.... while pulling my new travel trailer through the mountains this weekend I found out that my cooling fan clutch ain't doing its job. Well it will work if I pull over then start again but it won't turn on again till I pull over again. Had a few tense moments and she got a bit hotter than I would like but in the end I never hit RED thank goodness.
Ok so here is the question, Hayden Severe Duty Thermal Fan Clutch, AC Delco, 4 seasons or some other version.... any opinions out there?
Also While i am at it I am going to replace my AC compressor clutch that screams at me during hard accelerations has any one done this job?
Thanks,
Ryan
Colorado Camper Van poptop
4x4 - NP236 Transfercase
Propex HS2211 propane heater
See my build here
Snowgeek
Re: Radiator Fan Clutch choice
Post by Snowgeek » Thu Jul 19, 2018 5:38 am
Ok so I ended up going with the AC Delco thermostaticly controlled fan clutch, Amazon had this for $95..... this is quite a bit more than a few other after market clutches but after reading a few reviews many of the others seemed to have mixed reviews.
Ryan
See my build here
Bret Schmerker
Post by Bret Schmerker » Sat Nov 24, 2018 6:33 pm
:cheers: Good choice there! I'm planning on going ACDelco® this spring for a fan reclutch -- I had to replace a seized water pump recently, but my stock fan clutch is good for now and the typically mild Central Valley (CA, USA) winter is none too demanding on cooling systems.
