Alternators - Who do you trust?
Battery, alternator, starter, cables, etc.
ihatemybike
Post by ihatemybike »
Since Green appears to need a new alternator.
What brands do you like?
Which ones would you avoid?
Re: Alternators - Who do you trust?
Post by mdmead »
In the past, I always used Napa for parts that might leave me stranded if they broke. I don't have that much faith in them anymore.
I put an Autozone Duralast alternator in my Super Duty last fall and it worked out of the box and has been trouble-free so far.
Post by Smiliesafari »
OCA is a brand you can trust. I've used them for 30 years without a failure.
Been thanked: 2 times
Post by astrozam »
The 1st time I had to replace my alt I went with A.C Delco, can't remember if the 2nd one was A.C or not :-k weird
SoCalli V8
Retired
Retired
Post by SoCalli V8 »
I will only fit brand new AC Delco Alternators.... > after been-ing stranded in the 200 mile desert , and being stranded twice now....
AC Delco is the only way to go......
phr1$k37
Post by phr1$k37 »
AC Delco, did mine Christmas 2008 the day before boarding a ferry :)
ihatemybike
Took the thing off, had it tested. Still good. Reinstalled it.
phr1$k37
Post by phr1$k37 »
ihatemybike wrote:Took the thing off, had it tested. Still good. Reinstalled it.
So if it is good, then why did you post you need a new alternator? Battery not holding a charge? Or Charging system is bad? BTW ... how frequently will charging systems go bad?
I waited for 2 years for my alternator to die hah ha. And of course it did the night before I was to board a ferry for a 1200km trip. But it died while I was on freeway with about 200kms to drive :D Murphy's Law.
