Engine light and rough running
Topic author - I get chills without my van.
Got a tuneup a month ago and the van has been running well. Yesterday on the way to work, with no warning or incident to initiate it it began to run rough, like a plug wire was off or something and the engine light alternates from flashing to full on. It's a 2004 front wheel drive. I've spent $3000 on this thing in the last month and I'm running out of cash and patience. Does anyone have any ideas?? Thanks for the read.
Windsor, Ontario
2004 GMC Safari SLE
2004 GMC Safari SLE
Re: Engine light and rough running
have you taken the doghouse off to look for a plug wire that mighta fallen off ?
I haven't. Will that cause the engine light to come on?? Heat and oil pressure were good.
Windsor, Ontario
2004 GMC Safari SLE
2004 GMC Safari SLE
Did you just fill up with gas? Maybe water in the gas. Check plug wires and coil wire. Pull the cap off and inspect it and the rotor.
Did not just fill up. Thanks for the ideas and I'll check them out.
Windsor, Ontario
2004 GMC Safari SLE
2004 GMC Safari SLE
Had the van scoped and came up with an op300 code. The mechanic found that when I had the air conditioner compressor changed, they had damaged the ignition coil. He changed that and the ignition module and now all seems well.
Windsor, Ontario
2004 GMC Safari SLE
2004 GMC Safari SLE
