idles fine but back fires when under load ?
Re: idles fine but back fires when under load ?
There is no cat on my van its an 89 and is not required in NH but thanks for the info I will need it when I move to California in the future.
I think it was lifted that suggested pulling the o2 sensor infront of the cat to releive the back pressure when testing for a plugged cat. I thought that was a good idea if your ca is welded in instead of bolted. If its bolted you can just undo the clamp.
1999 Safari Touring edition.
teal green
300 000 kms
teal green
300 000 kms
It does not have a cat converter, I removed it way before I did the engine swap.
its raining hard here in NH so when it stops I am going to check a bunch of things, ignition timing to be first because I am wondering if they set the timing without unplugging the wire on the distributor.
Just for kicks, while you have the timing light all set up, shine it at your fuel injectors while running to see if it is a nice cone shaped spray pattern, or a bunch of dripping drops. (air cleaner removed of course)markmitchinnh wrote:its raining hard here in NH so when it stops I am going to check a bunch of things, ignition timing to be first because I am wondering if they set the timing without unplugging the wire on the distributor.
I like to disconnect the battery for 5 minutes before I start on the tune up.
That way, I know the computer is basically at the default settings, and has cleared anything it may have learned or adjusted.
Also, is the gas in the tank very old?
I started the engine swap in August and there was possibly 5 gallons in the vans tank I added another 5 gallons at the shop with half a bottle of dry gas added to it.
