rough idle and misfiring
1999 Chevy Astro 156k
Accel Cap/rotor
Ac Delco Irridim plugs
Omni-spark wires
Cherry Bomb Glasspack
Spectre Air Filter
ive replaced the cap/rotor, plugs and wires, catalytic converter, fuel filter, PCV valve and vacuum lines and its still misfiring and rough idle.
i think its the timing but how the hell do you check the timing on these vans? its not throwing any codes.
i think it could be a bad Crankshaft Position sensor and the Ignition Control Module.
Accel Cap/rotor
Omni-spark wires
Spectre Air Filter
Re: rough idle and misfiring
im gonna clean the EGR when i get some money. im also gonna replace the ICM
1999 Chevy Astro Custom Craft
Cherry Bomb Glasspack (27' inch with 3' inch O.D and 3' I.D)
Spectre Air Filter
Stampede Bug Deflector
MTX Thunderbird speakers
cars owned:
(shit cruiser) 1991 Mazda 2.2 Lt 5-speed 626 146k-154k
(The Lay-Z Boy) 1993 Buick Roadmaster 5.7 350
(after i donated my mazda due to problems i drove the Buick for 3 months, then i got the van as a Christmas gift.
Spectre Air Filter
cars owned:
Inspection and cleaning of the EGR Valve costs nothing...
Replacing components that haven't failed costs more than even I have to spend.
Good Luck, Jim
Good Luck, Jim
wow...i sure hope all of those part replacements were justified.
I had issues with the idle air control valve on mine, does your have one?
i don't really know if my 99 astro has an idle control valve. but where is the EGR valve on my van?
the one thing that im gonna replace no matter what is the ignition control valve and once i find the EGR valve its gonna be cleaned.
its started to miss and idle rough once i had my Cherry Bomb glasspack installed.
Spectre Air Filter
cars owned:
Spectre Air Filter
cars owned:
Chances it is the cap/rotor and wires. These engines are very picky on ignition parts. OEM is what makes them run best. We've seen it here a hundred times where new aftermarket parts fail after a very short time.
i have not changed my cap/rotor since August 12k miles ago. it still has the Accel cap/rotor.
i replaced the wires with Omni-Spark from O'reileys for $33, they were replaced last week 100 miles ago.
when i get my taxes im gonna clean the EGR and put a new cap/rotor.
where and what kind of cap/rotor should i install? Duralast Gold?
Spectre Air Filter
cars owned:
Spectre Air Filter
cars owned:
Because of the heat found in the engine bay area. It has been said that AC Delco Cap and Rotor are the best.
It is what I use, and what others recommend.
Good Luck and Keep us posted.
Ac Delco it is for me. THANKs
what should i use to clean the EGR valve?
Spectre Air Filter
cars owned:
Spectre Air Filter
cars owned:
Carb cleaner will work on the EGR.
Go here: http://www.gmpartsgiant.com/Page_Produc ... =TM0330401DSkidds wrote:but where is the EGR valve on my van?
Click the BLUE Get Info button, Then click GO...
There is your EGR Valve. It will prolly be dirty, like this: Clean it up real good to look like this: Make sure you go to your local auto parts store and buy an EGR Valve Clean Screen, Like this: I would recommend that you do these things before you spend another penny.
Good Luck, Jim
Just a thought.Take the O2 sensor and temporary remove it.Run the engine with it off to see if it improves the idle.If it does,then the O2 sensor is bad.
Also take the van to a local parts store.Many of them will scan the van for codes for free.
as of now i don't have any money so next paycheck im gonna buy stuff for the EGR valve.
when i was driving home the check engine came on. (it was on before) its saying P0300 (random/multiple misfire)
so next week im cleaning the EGR valve. when my taxes come im replacing the cap/rotor with the AC Delco brand. if those don't fix it then im replacing the Ignition Control Module
cap/rotor $55
ICM $85
cap/rotor $55
ICM $85
Spectre Air Filter
cars owned:
Spectre Air Filter
cars owned:
