2000 astro wont start cold
rustyvan
Post by rustyvan »
Have a new to me 2000 astro with a vortec when cold wont start will crank over an over an nothing. Give a shot of eather will fire an run great. Can shut off an starts great run normal no codes only happens once in awile not all the time. Was thinking fuel pump but runs great.
ihatemybike
Re: 2000 astro wont start cold
Post by ihatemybike »
Been here a couple times before. Your fuel pump is no longer able to pressurize the fuel lines high enough to start the engine cold, but is still generating enough pressure to keep the engine running. Time to put in a new pump and fuel filter. ACDelco or Delphi if you are keeping the van longer than 6 months.
rustyvan
Post by rustyvan »
Thats what I thought thanks just sucks this will be the fifth time changing fuel pumps in vans. Miss the old days of just swaping on the motor. Cheers
ihatemybike
Fifth time!?!?!?
How many miles are on it? What brand of pumps are you using? Are you regularly changing the fuel filter?
rustyvan
Post by rustyvan »
This is my seventh astro van so done afew of them
ihatemybike
Oh, originally thought fifth pump in one van.
Let's see.....I've done five, in four vans.
