97 astro van
howso48
97 astro van
Post by howso48 »
Have you encountered the the access to the fuel pump from the floor yet??/ or know anybody else that has??/My question is how would a person map out the location :bounce: to the access (as to where the pump is located under the floor??/)to be cut and how big of a area to remove??/ :prayer: please reply Steve
Re: 97 astro van
Most just drop the tank. It will need to come down anyway since there is a piece of sheet steel over the pump assembly. It is wedged between the tank and body crossmembers. If you do want to cut, just measure off the seat mounts.
Drummernaut
Re: 97 astro van
Post by Drummernaut »
This access hole has been done several times. The link here has the best view of were to cut:
http://www.astrosafari.com/viewtopic.ph ... mp#p170483
97CargoCrawler
Re: 97 astro van
Post by 97CargoCrawler »
Ditto on dropping the tank, at least the first time. Some vans don't have it but that protection plate is thick and sits too close to the fuel lines to cut through and not mess something up. Drop the tank and replace the pump, cut a hole and toss that plate in the trash.
Or you could maybe lower the tank just enough to yank that plate out and then cut a hole.
Put something like this in:
1997 SAFARI 2WD CARGO
howso48
Re: 97 astro van
Post by howso48 »
97CargoCrawler wrote:Ditto on dropping the tank, at least the first time. Some vans don't have it but that protection plate is thick and sits too close to the fuel lines to cut through and not mess something up. Drop the tank and replace the pump, cut a hole and toss that plate in the trash.
Nice Work!! So what holds the plate to the top of the tank??/
Re: 97 astro van
The tank straps.
97CargoCrawler
Re: 97 astro van
Pressure. The plate gets wedged between the floor and the tank and the pressure from the straps under the tank hold it there.
I'm not sure it it can be pulled without lowering the tank all the way, but may be worth a shot. It's like 16ga. steel. You may be able to carefully cut it or peel it back like I have seen some do. It may not be too pretty. Sorry I dont have any precise measurements for you. Best bet is to cut a small peep hole and see where you land. Then cut a big hole in the proper spot. For me that electrical panel door fit right in between the floor supports.
Just one option if you like things to look nice when your done.
Drummernaut
Re: 97 astro van
97CargoCrawler!!!!!!
That looks way too cool.
