99 safari won't start
Re: 99 safari won't start
The key word in my question is "New".timelessbeing wrote:He said 38 PSI Jim.
His "Old" fuel pump read 38psi, Hence the replacement.
So Again... New Fuel Pump Pressure Is?
I would put the original ECM in and try that. If it still doesn't want to fire, you may need to look at ignition items now. When was the last time the plug, wires, cap and rotor were changed? Does it fire on starting fluid?
Yes it does fire on starting fluid . Guess i'll check the injectors again !
replaced Spider injectors AGAIN ! This time it fired right up ! Going to re-install everything and take it for a drive to see how it does.
