fuel pressure
Tank, pump, filter, regulator, injectors and poppet valves etc.
Loner62quiet
fuel pressure
Post by Loner62quiet »
I have a 2000 astro with a no start problem every one says check fuel pressure. I have GM shop manuals for my van and cannot find out where to connect pressure gauge aby help would be appreciated,
justice
Re: fuel pressure
Post by justice »
There should be a connection near the back of the engine. You will need to remove the dog house to get to it.
Now, my neighbor had a 1999 Astro that would not start, and it seemed like a fuel pressure issue, but it turned out to be the cheap dist cap and rotor he installed. When he replaced them with good AC Delco parts the van started right up.
Current - 2004 Astro Cargo
Former
95 Safari (money pit - sold)
93 Astro Cargo (totaled)
92 Astro Conversion (sold)
87 Safari Shorty (sold)
Mmusicman
Been thanked: 2 times
Re: fuel pressure
Post by Mmusicman »
There should be a "shrader valve" (sticking up) on the fuel line at the back of the intake manifold, behind the fuel injection system.
Side note: Fuel pressure also depends on a pressure signal from the oil sender... but will still activate briefly when the key is first turned on.
AstroWill
Re: fuel pressure
Post by AstroWill »
Mmusicman wrote:Side note: Fuel pressure also depends on a pressure signal from the oil sender...
That is only on the older generations. From 99 and up the VCM uses distributor reference pulses to keep the pump running.
