Odd Vibration
ANYTHING TO DO WITH MAKING YOUR VAN MOVE EXCEPT FOR THE ENGINE ITSELF.
dobaroy
Odd Vibration
Post by dobaroy »
On our AWD '03 Safari, when we are in tight corners in a plaza, the van will give off a vibration that you can feel, even in the steering. Changed the rear end and transfer case fluid but that didn't work this time. Any suggestions would be appreciated. Thanks
Re: Odd Vibration
Did you use the Auto Trac 2 fluid in the t-case? You may need to flush it again to get fresh fluid in all the clutches. They sometimes take 2 flushes if the fluid was really black and had a lot of miles on it.
thegreenmachine
Re: Odd Vibration
Post by thegreenmachine »
x2 on the reflush.
I had to do it 3 times to get rid of the binding at parking lot speeds and tight cornering.
2003 Chevrolet Astro 4wd np233c transfercase 245/75/16 ETS Trailermaster tires
Previous:
1995 Safari AWD (death by torsion bar. a.k.a. "the final straw")
1999 Safari AWD ( death by tree x2 )
1997 safari rwd cargo ( sold @ 450,000+ km )
dobaroy
Re: Odd Vibration
Post by dobaroy »
Thanks for the replies and yes we did use the Auto Trac II Fluid. It was approx. 25,000 miles between times we did the flush, but seems like we should do it again.
dobaroy
Re: Odd Vibration
Post by dobaroy »
We changed the fluid for the second time and it came out real clean . . . no change, the shudder/vibration is still there (NOT CONSTANT just comes and goes) and even if you put the van in park, and that is with the wheels not turned to the left or right, you can still feel it in the steering wheel. Any suggestions would be appreciated.
Re: Odd Vibration
Might want to check out the motor mounts. While you feel the vibration, look under the van and in the engine compartment for any vibrations. Make sure the exhaust isn't rubbing on something as well.
Re: Odd Vibration
X2 on the rubber engine and transmission mounts.
Worn out, they allow for lots of odd vibrations.
