It is currently Tue May 22, 2018 11:13 pm
Post new topic Reply to topic  [ 10 posts ]
 Post subject: Idler Arm Replacement Procedure
PostPosted: Wed Mar 04, 2009 7:22 am
Idler Arms can and will eventually fail. Mine just went around 115K miles. You'll notice they're bad by grabbing a front wheel with one hand on each side when the vehicle is jacked up and noting excessive play as you push and pull. Anyway, mine just failed state inspection, so now here's how they're changed.
1. Jack the front of the van and remove the front wheels for ease of working. Now here is the idler arm--note that I sprayed it with some PB Blaster to make the bolts easier to remove--something like that or WD40 would not be a bad idea at this point:
2. Remove the two bolts closest to the front bumper. On the 2003 model, these are 18 mm bolts. Here it is with them out:
3. Remove the prevailing torque nut from the idler arm ball stud, shown below. Note, on 2003 model, this is an 18 mm bolt. Also, if it's been replaced it may have a carter pin in it--obviously, if it does pull that first
4. Now use a tie rod separator to remove the relay rod from the idler arm. Note, while shopping for tools I found out they make tie rod separators for air hammers--COOL! But it may actually be just as easy with the standard long hand held tool... EDIT--READ THIS: I heard that if you do what I did you could damage stuff--apparantly I got luck. They make a special tool for this, and for $20, just get it. Here's what I'm talking about: http://www.jcwhitney.com/LISLE-TIE-ROD-EXTRACTOR-FOR-VOLKSWAGEN/GP_2004138_N_111+2003+200728437+600018015_10101.jcw The photo below worked for me but you could damage your tie rods:
5. Tighten the nut in the center of the new idler arm to 40 ft/lbs--I did this in my vice prior to installation...
6. Install the new idler arm. Note: I found that a deep well socket on a breaker bar works great to seat the ball stud, when applied from underneath and lifted up. Here it is before seating that and tightening the bolts:
Torque settings:
* The two bolts closest to the front bumper should be tightened to about 105 ft/lbs
* The bolt in the center of the idler arm should be tightened to 40 ft/lbs
* The prevailing torque nut should be tightened to 35 ft/lbs.
Notes:
* Remember to install the grease fitting(s) if not already on the part
* Remember to grease all grease fittings when done
* I am only providing this procedure to tell you how I did this. In no way am I telling anyone to do this, especially if they're not comfortable with this repair. Also note, I'm a chemist not a lisenced mechanic, so as with all things, consider the source.
I would like some more experience folks to comment on what this does to the front end alignment and to double check my torque settings...
2007 Chevy Cobalt
 Post subject: Re: Idler Arm Replacement Procedure
PostPosted: Wed Mar 04, 2009 11:43 am
Nice write-up! Torque specs sound about right. The alignment will not be affected by the replacement unless it was way off to begin with.
PostPosted: Wed Mar 04, 2009 12:35 pm
Some manufacturers are getting tough with their 'Guarantees' .Moog is starting to ask for old idlers and only warranting after inspection.
Grease the front end EVERY time you change your oil!!!!!!
also.....do yourself a favor and buy a off-set/90* slide on fitting for your grease gun.This makes acessing those grease nipples alot easier. :guitar:
Good write-up =D> because these vans eat idlers if the idlers are not maintained correctly.
PostPosted: Wed Mar 04, 2009 1:27 pm
Online
Good job. I went to check my idlers and there aren't any. #-o Oh yea...I remember...I got rid of those POS parts. :muhaha: :muhaha: :muhaha:
PostPosted: Wed Mar 04, 2009 2:01 pm
:muhaha: :muhaha: :muhaha: wiseass!!! :muhaha: :muhaha: :muhaha:
YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE.
DAILY THOUGHT:
SOME PEOPLE ARE LIKE SLINKIES - NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
PostPosted: Wed Mar 04, 2009 11:13 pm
Online
Sometimes I just can't help myself. :muhaha: :muhaha: :muhaha: Boy... aren't we back to our old self? \:D/
PostPosted: Wed Mar 04, 2009 11:22 pm
Hey , I gotta be me !!!! :D :D :D
DAILY THOUGHT:
PostPosted: Wed Mar 04, 2009 11:46 pm
Online
Really glad to hear it, Skippy. It's really brave of you to go through that surgery. You wont regret it. It'll add years to your life. \:D/
PostPosted: Sat Mar 14, 2009 4:53 am
Most of you probably know about this one, but I didn't at the time. Step 4, the way I did it can damage tie rods from something I heard. Apparantly they make a special tool just for separating these from the tie rods. It can be had cheaply, and you don't risk damage using it.
2007 Chevy Cobalt
PostPosted: Sun Sep 01, 2013 8:45 am
Thanks for helping me with your great write ups!
Just replaced both idler arms in a 1995 astro service van and thought I would add a tip:
If your ball joint seperator won't do the trick, I've found a pitman arm puller will JUST fit. Apply slow and easy tension to the bolt (don't rush it). The constant pressure will finally crack the old boys loose.
Again, thanks for all the great tips on astro vans! Saved me a ton of cash in the last 2 years!
Current ride:
1995 Astro Service Van (CL special $900!)
2006 Cadillac SRX
1999 Acura 2.3
Users browsing this forum: No registered users and 3 guests
