DIY lift kit 2003 Safari
rvflyfish
Re: DIY lift kit 2003 Safari
Post by rvflyfish » Sun Sep 14, 2014 1:29 am
Marktainium wrote:
photo_van wrote:We have very close to the same overall miles re: idler arms. Thanks for the greasing tip.
I'm curious why you went with the s10 truck springs (1350#) rather than the s10 Blazer springs (1450#). Not a huge difference, but inquiring minds??? I've never been able to find a rating for my stock 2+1 springs, only 3+1 rated at 1410#s.
I rechecked the catalog as I couldn't remember why I wouldn't have done that. Then I remembered. They quote different capacities, but the spring part numbers are the same. I was happy with the ride quality of my stock springs, so didn't do the HD springs. I didn't want to need to wear a kidney belt when the van had no load in it. If I have a load issue I will turn to air bags or air shocks.
Never mind, I think I figured it out; Astro springs don't have enough arch.
Follow up question: Is it just the pics because you're towing, or is the front a little higher than the rear (to the eye). I know your measurements show the rear to be almost 2" higher, but in the pics it looks a tiny bit lower than the front.
photo_van
Post by photo_van » Sun Sep 14, 2014 1:36 am
I can't speak for the OP, but the standard frontend lift of 2" body pucks and 2" of torsion bar crank, give 4" in front. S10 leaves give 3" in back. I used shackles and new holes in the spring hangers to gain another 2" in back.
pbgbottle
Post by pbgbottle » Tue Jan 15, 2019 1:55 am
Bump for another local guy getting ready to do mine 04 AWD in cloverdale.
And issues or updates to add to this thread. I have been thinking of just ordering a kit from journey off-road. A bit pricey in Canadian funds. But I like their rear brackets for the front solid mount of the springs. I may go through the headache of installing the three inch blocks also. ,,cheers cool thread I have never seen your rig around before.
2004 astro AWD
rvflyfish
Post by rvflyfish » Tue Jan 15, 2019 4:34 am
There's a thread about a 3+1 lift on here or the other Astro/Safari forum. That's 3" pucks and 1" torsion bar crank.
I did a 2+2 lift but if I had it to do over again I would go 3+1. Less cranking of the torsion bars gives a better ride.
Btw, I used rear leafs from SDTruckSprings.com and the rear end is a little higher than the front. It has a nice little rake to it. Part #22-687. USD130 plus USD106 shipping.
Chase1
Post by Chase1 » Mon Jan 21, 2019 3:22 pm
great post thanks, helpful stuff.
Post by Astrophysics » Tue Jan 22, 2019 4:23 am
Yes, the shop in Prescott AZ, Journeys Off Road, JOR,
Offers the 3" pucks
Mike is the one to talk to.
He also sells the awesome rear bump stops for lifted Astro.
