Overland Lifts ???
LaGrasta
Re: Overland Lifts ???
Post by LaGrasta » Thu Mar 24, 2011 12:04 pm
"The 2 front most bolts give some folks headaches because they can spin around and around forever.
The secret is to not push up hard on those bolts or you lift the nut out of its retainer inside."
If you remove the front bumper first, you can add a wrench on the nut side of this bolt to keep it from spinning.
1998 Astro, 224,000 miles
K&N air filter
TruCool trans cooler
Post by timelessbeing » Thu Mar 24, 2011 8:03 pm
I thought the nut retainer was inside of the radiator support.
Post by Herbie » Thu Mar 24, 2011 10:56 pm
loopie wrote:The job can be done in 2parts too Eh. The van is driveable with just one end completed. So one end one evening, the other the next if you need to.
If you do it this way, please lift the rear first. Otherwise I will come over and make snide comments about how funny your van looks with it's nose in the air. :poke:
Post by doyoulikeithere » Fri Mar 25, 2011 12:27 am
timelessbeing wrote:I thought the nut retainer was inside of the radiator support.
Ya, it isnt very accessible, so to avoid the need for cutting a hole or something like that to get at the nut, be careful not to push it up.
Post by timelessbeing » Fri Mar 25, 2011 12:44 am
Mine was a big PITA. The nut was rusted solid to the bolt which I hacksawed off. I didn't cut a hole though. Instead, I insertws a wrench through the hole in the side (pictured) to hold onto a new nut while I tightened the bolt. The nut retainer was just a flimsy piece of sheet metal. But in this province, we're used to everything being seized by rust.
Post by doyoulikeithere » Fri Mar 25, 2011 4:58 am
Yes, especially on this coast!!
I must admit I was very surprised that i got those out of an 87 van, without incident.
loopie
Post by loopie » Fri Mar 25, 2011 5:45 am
You see, I'm the exact opposite. I hate seeing vehicles with the rear higher than the front.
The rear lower has a Baja or Desert Prerunner look if you use the right bumpers :supz:
I think I snapped a pic of mine with just the front done....
Post by doyoulikeithere » Fri Mar 25, 2011 3:01 pm
Looks pretty nice Loopie!
I am concerned about all that body cladding on the lower body and around the wheels.
It looks in that pic like there isnt a helluva lotta room around the rear tires for spring flex. if you go over a rock or a log, your rear tires can collide with the body at the front lowest corner of the wheelwell.
Maybe just an optical illusion, but these vans do like to rub there. I ripped almost every lug on a brand new BFG, just by going thru a dip, when I first did a 2" lift.
I suggest you have a friend back your van up onto a ramp on 1 side only, slowly, keeping the other wheel on the ground, and watch for that rub spot/tire damage potential. It might be surprisingly easy to find! Personally, I would ditch the pretty cladding too. but thats just me and I'm, well, not average.
Now I have way more rear lift and its entirely springs, no blocks. Seems to have no rubbing now.
rastafari03
Post by rastafari03 » Fri Mar 25, 2011 10:36 pm
I thought I read someones post stating that the AWD's had to ride level. I plan on going all weekend if need be anyhow.
Also got home yesterday and their were boxes on the porch, like a kid in the candy store!!! Gerald sent the shackles, spacers and...heck didn't really fish through the whole box. Still missing the bigger stuff, springs etc. So that's cool.
Thanks and Happy Friday.
Sean
Lov'in my new beach buggie!
03 Safari AWD SLT 3D 99k Mods: 4" OLV lift, Rancho 5000 shocks, Two new front half shafts, True-cool trans cooler, removed cladding, (n)Z71 offroad decals, Yakama cross bars and fairing, Malone kayak cradle, matte black 16" x 8" MB wheels and 255/70/16 Pirelli Scorpion ATR's.
oldsmoker
Post by oldsmoker » Sat Mar 26, 2011 12:18 am
can anyone tell me where I can get standard replacement frame to body mount bushes/pucks??....best brand to get, and er, how many are there in total? thanks.
Cobra
Post by Cobra » Sat Mar 26, 2011 12:22 am
there was a thread on the body bushings gm part numbers i did a quick search this should be it
viewtopic.php?f=67&t=1967&hilit=body+mounts
oldsmoker
Post by oldsmoker » Sat Mar 26, 2011 1:19 am
thank you! :guitar:
loopie
Post by loopie » Sat Mar 26, 2011 6:02 am
doyoulikeithere wrote: I am concerned about all that body cladding on the lower body and around the wheels.
Thx.
There is more room than it appears in that pic for sure...but in that configuration(2" front, 0" rear)...I only carefully went to the Beer store and back.
The rear is in now and I'll be double checking clearance under full load/torque but really, the traction bar(reducing spring wrap) and the fact that I also moved the rear axle back 3/8"...the tire can't get anywhere near the front of the wheel opening :supz:
OKflyboy
Post by OKflyboy » Mon Mar 28, 2011 9:44 pm
Getting ready to do my lift here in the next month or so. I already have the shackles for the rear, and pucks for the subframe. Can anyone tell me the size, length and thread pitch I need for the subframe bolts for a 2" puck?
LaGrasta
Post by LaGrasta » Mon Mar 28, 2011 10:21 pm
OKflyboy wrote:Getting ready to do my lift here in the next month or so. I already have the shackles for the rear, and pucks for the subframe. Can anyone tell me the size, length and thread pitch I need for the subframe bolts for a 2" puck?
Of the six puck/bolt combo, there are two different size bolts. My suggestion is remove the back and middle bolts and make a parts run getting the same, but 2" longer.
K&N air filter
